learning to weld TIG
Old Feb 21, 2006 | 11:07 AM
640K Crew's Avatar
Default learning to weld TIG
ive been wanting to take up welding for a long time and i keep missing the sign up dates for community college. i was going to just bite the bullet and buy a tig welder and start messing around.
id think i should start with mig and work my way up to tig but almost everything i want to weld requires tig.
when i do get in the classes i have to go in order and start with arc welding and i think tig is like the 4th class so by the time i get all the pre requisites out of the way i probably wont be in a tig class till late this year.
is it a dumb idea to get a tig welder (oconotig) if ive never welded in my life?
ps. ido have a buddy who was a fabricator so i think he knows a good deal and will help me out with hard ?'s
Old Feb 21, 2006 | 11:18 AM
.dave's Avatar
i HAS questions ?
Default Re: learning to weld TIG (Drum and Bass Racing)
I learned TIG with no prior welding experience whatsoever. I tried MIG the last night of the course and it was very easy to pick up. Check with your local welding supply shop and see if they offer courses. I took mine through a local store that has a room set up for classes, clinics and even for if you want to try out certain products before you buy them.
Old Feb 21, 2006 | 11:30 AM
640K Crew's Avatar
Default Re: learning to weld TIG (daveG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG &raquo;</TD></TR><TR><TD CLASS="quote">I learned TIG with no prior welding experience whatsoever. I tried MIG the last night of the course and it was very easy to pick up. Check with your local welding supply shop and see if they offer courses. I took mine through a local store that has a room set up for classes, clinics and even for if you want to try out certain products before you buy them. </TD></TR></TABLE>
cool ill look into that. anyone know any good classes local to orange county?
Old Feb 21, 2006 | 02:45 PM
dfoxengr's Avatar
you dont step up from mig to tig, almost everything about them is different.
a good step would be oxy to tig. oxy is really cool in my book.
Old Feb 21, 2006 | 05:55 PM
3s-gte sw20's Avatar
Default Re: learning to weld TIG (dfoxengr)
yeah O/A is exactly like tig. make a puddle, add filler. the first time i jumped on the tig i was laying down perfect beads on steel, aluminum and stainless.
so if youre gonna go to school for welding just do O/A then quit and get your tig.
Old Feb 21, 2006 | 06:06 PM
dfoxengr's Avatar
Default Re: learning to weld TIG (3s-gte sw20)
yeah same here.
not perfect. but pretty good for first time.
Old Feb 21, 2006 | 08:29 PM
danielm3's Avatar
Here is an 8 hour progress ( 8 hours total ever welding in TIG ) of my TIG skills (not much ), https://honda-tech.com/zerothread?id=1529129 get a good machine, do some reading and practice practice practice
pantherballhp
Dec 13, 2010 07:28 AM
jdm_vtec
Welding / Fabrication
Jul 1, 2007 11:28 AM
dkim48
21
Dec 11, 2005 03:22 PM
ActiveAero
84
Oct 4, 2004 11:12 AM
WorkForHonda
Apr 22, 2003 07:57 AM
