ecu throwing code "5" can somebody explain pls.
Old Feb 20, 2006 | 10:44 PM
krz6jdm's Avatar
Default ecu throwing code "5" can somebody explain pls.
my dash check engine is on and when i checked it . it was throwing a code "5" I checked in the codes that you guys had and it was the map sensor so i exchanged it with a good one it's still on can somebody explain cuz there's a code "3" there too that says map sensor too. I just want to find out. thank you for any info.
Old Feb 21, 2006 | 01:09 AM
lv6l's Avatar
when you change the map sensor did you reset the ecu?
Old Feb 21, 2006 | 01:36 AM
Calvinator's Avatar
Default Re: (lv6l)
Im not sure if this is correct but theres 2 different map sensor codes because one of them is for electrical error like wiring, etc. and the other one is for mechanical error. Im not sure which is which though.
FSUseminoleEM1
Feb 19, 2010 08:34 AM
95gsrEG
Feb 17, 2009 06:45 AM
kaj
Sep 27, 2003 09:36 AM
logistixz
Jun 20, 2002 01:06 PM
Frosty_spl
Feb 12, 2002 02:06 PM
