H22 low rpm hiccup?
I tryed searching, but to no avail... when my engine is at around 1500-2000 rpm and I try to accelerate by slowely giving it more gas, I get a big hiccup once from the motor, it is like the engine cuts out and then goes... it only happens in lower rpms like i said above, and I cant seem to find the problem, I did plugs, wires are good, cap, rotor.... havent done the fuel filter yet, but I should have plenty of fuel at those rpms, since there isnt a high demand for fuel at that time. I am pretty much going to give up on it and just try to stay above 1500 rpm... but it also does it when taking off from a stop normally... it makes the whole car fall on its face... any ideas guys?
~Joe~
~Joe~
my car does that too, but only when under unnecessary load in low rpm's, for example it will happen in 4th at 800 rpms when I give it gas, but if I downshift to 3rd, it doesn't happen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">my car does that too, but only when under unnecessary load in low rpm's, for example it will happen in 4th at 800 rpms when I give it gas, but if I downshift to 3rd, it doesn't happen. </TD></TR></TABLE>
every car will do that...........btw thats not really that good for the car, but i'm sure you try not to do this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 »</TD></TR><TR><TD CLASS="quote">
That could have to do with your motor mounts, kinda like if you try to start off in 2nd gear, the whole front will kinda shake real nasty...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chronic H22 »</TD></TR><TR><TD CLASS="quote">
That could have to do with your motor mounts, kinda like if you try to start off in 2nd gear, the whole front will kinda shake real nasty...</TD></TR></TABLE>
it doesn't shake, just a split second hesistation, then it pulls normally.
every car will do that...........btw thats not really that good for the car, but i'm sure you try not to do this </TD></TR></TABLE>
most cars struggle until they hit a certain rpm range. That's not what my car is doing. its not a big problem though, only happens in 4th and 5th, 3rd and below have plenty of power to pull my car from any speed.
Yea mine is only a split second hesitation... I guess it will be ok... I have no codes.. although, I did fix my wiring to my 02 sensor, I had a broken signal wire. I never reset the pcm.. maybe that is why?
that_boy_sammy
Nov 18, 2013 02:15 PM
949
Sep 29, 2007 08:10 PM
