im hella paranoid.. should i be? help
today i jacked up my car using the handjack because i was about to swap rims. when i jacked up my front right side, the jack slipped and my whole front slammed to the ground. i can hear my oil pan hit hard. should i be worry about anything? messed up alignment? wheels? etc?
From: Dont say my car is topless say the titties is out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood »</TD></TR><TR><TD CLASS="quote">damn. check motor and tranny mounts.</TD></TR></TABLE>
also check suspension pieces and oil pan. I'd definately check the oil pan since it was probably hit the hardest
I dropped my teg like that, hit oil pan but the pan was fine. Not sure if your suspension is fine though cause mine was already bent, but I'd say you probably have nothing to worry about unless you see a huge dent in the oil pan or something, which I didn't get a dent at all
*edit - i think the tow hook was still on the jack when it fell though, cause I thought the car was on jackstands and lowered the jack...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 »</TD></TR><TR><TD CLASS="quote">crank shaft is the worst thing that could have broken..., which is pretty awful</TD></TR></TABLE>
how are you going to break the crank???
check the oil pan for large dents, if there are any remove the pan and inspect for damage, if there is damage, take pictures so someone on here can guesstimate how bad your fucked.
i'd so you got nothing to worry about. nexttime, use a floor jack and jack stands... live ya learn... right... hope all is well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr »</TD></TR><TR><TD CLASS="quote">how are you going to break the crank???
it falls on a rock and dents a counter weight
