Wanna know how to blow up your ECU?
Old Feb 20, 2006 | 04:09 PM
SupraRXZ's Avatar
Default Wanna know how to blow up your ECU?
Learn from my mistake...........see your negative terminal.......GET 50 WIRES COMING OUT OF IT AND GROUND IT TO AS MANY PARTS OF THE CHASIS!
or your car will not start and the power from the battery will go threw your whole engine harness including the ECU and expletive IT UP
now i gotta get a new ecu and theres about 7 or 8 ground wires coming from the battery
Old Feb 20, 2006 | 05:51 PM
beyondspexj's Avatar
why??
Old Feb 20, 2006 | 06:22 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Wanna know how to blow up your ECU? (SupraRXZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ &raquo;</TD></TR><TR><TD CLASS="quote">Learn from my mistake...........see your negative terminal.......GET 50 WIRES COMING OUT OF IT AND GROUND IT TO AS MANY PARTS OF THE CHASIS!
now i gotta get a new ecu and theres about 7 or 8 ground wires coming from the battery</TD></TR></TABLE>
WTF did you do again?
Old Feb 20, 2006 | 06:24 PM
e jay one's Avatar
Default Re: Wanna know how to blow up your ECU? (LSVT3K 91 C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ &raquo;</TD></TR><TR><TD CLASS="quote">GET 50 WIRES COMING OUT OF IT AND GROUND IT TO AS MANY PARTS OF THE CHASIS!</TD></TR></TABLE>
mad horse power or what?
Old Feb 20, 2006 | 06:26 PM
ghost_ryder35's Avatar
Default Re: Wanna know how to blow up your ECU? (e jay one)
I'm confused
Old Feb 20, 2006 | 06:33 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: Wanna know how to blow up your ECU? (ghost_ryder35)
u wana blow up your ecu take a welder arc to it.
Old Feb 20, 2006 | 07:47 PM
SupraRXZ's Avatar
I didnt have a good ground after doing my swap, so when i tried turning on the car the power went where ever it can ecu also, so it fried my ecu, and destroied resistors that were in it probably, and my car wont crank or start and the injectors are on full blast when i try to crank it, so lots of gas is coming out
Old Feb 20, 2006 | 08:28 PM
jdeemseerx's Avatar
i think i just went cross-eyed
Old Feb 20, 2006 | 08:41 PM
boostinaintez's Avatar
Default Re: (jdeemseerx)
me too
Old Feb 20, 2006 | 08:42 PM
M2S~Juan's Avatar
Old Feb 20, 2006 | 08:44 PM
Banned
Default Re: (SupraRXZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ &raquo;</TD></TR><TR><TD CLASS="quote">I didnt have a good ground after doing my swap, so when i tried turning on the car the power went where ever it can ecu also, so it fried my ecu, and destroied resistors that were in it probably, and my car wont crank or start and the injectors are on full blast when i try to crank it, so lots of gas is coming out</TD></TR></TABLE>
Old Feb 20, 2006 | 09:05 PM
SupraRXZ's Avatar
Default Re: (LSVT3K 91 C1V1C)
ok forget what i said, ECU is fine i tried it on my bro's EG, and used his ECU in my car same problem
Now I need to know why my car is shooting tons of gas, so much it comes out of my headers
and why my starter doesnt crank, it just pops (brought the starter in the store to get checked out, so i know it works)
And this happens when i turn the key
it used to be when i had bad ground...my dash lights were on and injectors were on and i didnt have the key in the car, i just put on the positive on my battery
Old Feb 20, 2006 | 09:12 PM
jdeemseerx's Avatar
you probably shouldve done a lil bit of research before you did the swap in the first place..just my 2 cents.. if you want honest answers why dont you start off by tellin us what motor, what ecu and what car.. oh and another thought.. take off the "50" ground cables while your at it.. you only need one from the battery im still cross eyed
Old Feb 20, 2006 | 09:20 PM
SupraRXZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">you probably shouldve done a lil bit of research before you did the swap in the first place..just my 2 cents.. if you want honest answers why dont you start off by tellin us what motor, what ecu and what car.. oh and another thought.. take off the "50" ground cables while your at it.. you only need one from the battery im still cross eyed</TD></TR></TABLE>
i already took the ground wires off execpt for the one i need
Engine - D16z6
ECU - P28
Car - 1990 civic hatch DX converted OBD1 Multi Point
SupraRXZ
12
Feb 22, 2006 04:37 PM
SupraRXZ
Feb 21, 2006 11:30 AM
red97EX
Sep 20, 2005 10:42 AM
Boring
10
Dec 3, 2004 11:31 AM
