obd2 to obd1 conversion?
ok, so my brother wants me to ask you guys since he is out of town. Does ne body make an OBD2 to OBD1 coversion harness for a 2000 p73 ecu?? or can i just move my seconday o2 sensor farther in the exhaust? and what is the difference between the primary and the seconday o2 sensor? i have an greddy e-manage and if take the seconday o2 sensor out would it go to the pre-set settings if the CEL came on.
If you want to switch to OBD1 you will need an OBD2b to OBD1 conversion harness and an OBD1 ECU (chipped or stock).
Once you switch to OBD1 you won't need the secondary O2 sensor as the OBD1 ECU does not look for it.
-kenji
-kenji
alright, the car is a 2001 right? what ECU are you trying to use? P73? That would not require a jumper.
So far what you have said has made little to no sense, but if you explain exactly what you're trying to do i'd be more than happy to try and help you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INTEGRA_boy »</TD></TR><TR><TD CLASS="quote">can my brother use his emange with this obd2b to obd1 conversion if he has the ignition and the injector harness?? cuz doesnt that take out the A and B plug?</TD></TR></TABLE>
You can't convert to OBD1 if you're using an OBD2 ecu. Whatever ecu you have.....thats what version of on board diagnostics you have. Even if you're only using one o2 sensor, its still obd2.
dem0nk1d
Aug 8, 2007 02:17 PM
trust01
Mar 2, 2006 04:18 PM
