ctr cam install
Old Mar 27, 2002 | 09:49 PM
erniecars's Avatar
Default ctr cam install
Im going to install my ctr cams and itr retainers and valve springs as soon as i can figure out what tools and seals/gaskets need to be replaced during the job. Im going to do the timing belt and water pump at the same time.
So far i know i need:
10mm valve adjustment tool
angled feeler gauge
spring compressor
valve cover gasket
cam seal/oil seals
timing belt
water pump
tensioner
Do I aslo need to replace the valve seals? Any other seals to replace? the helm has a lot shown in the picture that ive never heard of anyone replacing. Any other tools I will need?
Thanks!
Old Mar 28, 2002 | 07:51 AM
Kataku2K3's Avatar
Default Re: ctr cam install (erniecars)
headgasket, Hondabond or any other RTV silicone, oil or assembly lube (I prefer to use oil on a cam install, save the assembly lube for bearings) There might be some other stuff i forgot, but i can't remember anything right now!
Old Mar 28, 2002 | 08:00 AM
acura_typer's Avatar
Banned
Default Re: ctr cam install (JDMspecEG6)
Why a head gasket if you don't have to pull the head?
Old Mar 28, 2002 | 09:55 AM
erniecars's Avatar
Default Re: ctr cam install (acura_typer)
usually you do pull the head. i wasnt clear. Im going to try doing it without pulling the head and if i make a mistake or something i guess i will have to.
What about valve seals? do i need to replace those?
[Modified by erniecars, 6:55 PM 3/28/2002]
Old Mar 28, 2002 | 10:02 AM
RR98DX's Avatar
no.
Old Apr 9, 2002 | 02:46 PM
vtec2nr's Avatar
You've probably seen this, but if not.... http://hybrid.honda-perf.org/tech/cams.html
prodjay10
Honda Civic (2001 - 2005)
Jul 4, 2016 10:27 AM
jdm b16 eg
Sep 22, 2014 06:19 AM
bungalo101
Mar 13, 2014 10:00 AM
Mhollaek9
Sep 12, 2007 07:16 PM
omahajim
Apr 17, 2004 02:16 PM
