Bad dizzy or bent valve?
Old Feb 20, 2006 | 10:48 AM
NeriVTEC's Avatar
Default Bad dizzy or bent valve?
Ok so I went to start my car and it had a weird idle, smelled gasoline coming out of the exhaust, and the motor was shaking. So I checked my plugs, they were fine minus #4 that was wet with gasoline. So I put them back and checked the wires by taking one out at a time and when I pulled #4 the motor didn't change the sound, it was like if that cilinder wasn't working. After this cel 9 came on. Turned off the car, started it up again same stuff happening but no cel 9. Also some smoke is coming from the exhaust and I'm assuming it is from the unburnt fuel. Could this be a dizzy problem related to cel 9 (cylinder position sensor) or would this be signs of a bent valve? Already searched and I'm between these two.
Old Feb 20, 2006 | 11:07 AM
The_Sober's Avatar
Default Re: Bad dizzy or bent valve? (NeriVTEC)
it could be your dizzy, but I would try replacing that plug first and seeing where it goes from there. I doubt it's a bent valve...those don't just bend out of the blue. If you swap the plug out and it's still happening, check your distributor cap and rotor.
first and foremost, replace the plug and check to see if you have spark. if not, then it's probably the wire and/or cap/rotor assembly.
Old Feb 20, 2006 | 11:11 AM
NeriVTEC's Avatar
Default Re: Bad dizzy or bent valve? (The_Sober)
Already did change the plug and came out black and wet with fuel.
Old Feb 20, 2006 | 12:56 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Could be a bad wire or distribution cap. Swap the wires from one of your other cylinders.. be sure to change their firing order on the cap as well.
Old Feb 20, 2006 | 03:56 PM
NeriVTEC's Avatar
Default Re: Bad dizzy or bent valve? (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">Could be a bad wire or distribution cap. Swap the wires from one of your other cylinders.. be sure to change their firing order on the cap as well.</TD></TR></TABLE>
If this were the case could a cel 9 appear, even if the sensor is fine?
Old Feb 20, 2006 | 04:02 PM
JDMC-Kamel's Avatar
distributor cap and rotor, possibly bad wire.
exchange #4 with #3 and see if it changes.
might be slight electrical issue.
Old Feb 20, 2006 | 05:01 PM
NeriVTEC's Avatar
Default Re: Bad dizzy or bent valve? (JDMC-Kamel)
So all of my problems could be a bad rotor or cap, instead of the whole dizzy?
lazieb29
Nov 22, 2009 09:34 AM
junioman
May 21, 2009 09:00 AM
ED8REX
Apr 25, 2006 09:25 PM
TYPErCRX
Jan 24, 2006 05:22 AM
ek_will
12
Sep 29, 2004 02:35 PM
