Smell after test pipe install
Old Feb 20, 2006 | 09:39 AM
ITR198's Avatar
Default Smell after test pipe install
For you guys that have test pipes does it smell after you go into v-tec and come to a stop. or even all the time also did it make your car smoke when v-tec engages
Old Feb 20, 2006 | 09:43 AM
white rocket's Avatar
Default Re: Smell after test pipe install (ITR198)
You will smoke a bit more because you'll be running a little rich, if no tuning is done after the fact. Since there is no cat in place the lovely "rotting egg" smell will become apparent, mostly for the people behind you
Old Feb 20, 2006 | 10:08 AM
itr1244's Avatar
Default Re: Smell after test pipe install (white rocket)
haha yeah it just stinks cuz nothing gets filtered lol
Old Feb 20, 2006 | 04:21 PM
warwagon's Avatar
hehe mine only stinks when i roll the window down
Old Feb 20, 2006 | 05:28 PM
erikiksaz1's Avatar
Default Re: (warwagon)
Just hope the cops don't notice
Old Feb 20, 2006 | 05:47 PM
Jon D's Avatar
You will find that with a test pipe you are going to have a residue build up close your bumper area just above your muffler as well as on your hatch and even sometimes the bottom side of your wing. When you wash your car, simply spray some degreaser on your hand and gently rub it over the residued spots. Make sure you quickly wash it of though, then rewash with soapy water. That will take care of the residue issues though. Oh and make sure you keep that area of your car waxed at all times, will help with the protection of you paint
Old Feb 20, 2006 | 07:09 PM
jdm_DC2R's Avatar
Default Re: Smell after test pipe install (Jon D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D &raquo;</TD></TR><TR><TD CLASS="quote">You will find that with a test pipe you are going to have a residue build up close your bumper area just above your muffler as well as on your hatch and even sometimes the bottom side of your wing. When you wash your car, simply spray some degreaser on your hand and gently rub it over the residued spots. Make sure you quickly wash it of though, then rewash with soapy water. That will take care of the residue issues though. Oh and make sure you keep that area of your car waxed at all times, will help with the protection of you paint </TD></TR></TABLE>
i have small black dots all over my bumper and under like the rear wing, and i have a factory cat in there, imagine when i put in a test pipe! and yes, i wash and wax it extra more in those areas, it helps out!
Old Feb 20, 2006 | 07:33 PM
itr1244's Avatar
Default Re: Smell after test pipe install (jdm_DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">
i have small black dots all over my bumper and under like the rear wing, and i have a factory cat in there, imagine when i put in a test pipe! and yes, i wash and wax it extra more in those areas, it helps out! </TD></TR></TABLE>
those black dots are your oil that's burning away
Old Feb 20, 2006 | 07:40 PM
JjuuN R's Avatar
Default Re: Smell after test pipe install (itr1244)
wow, i've never dealt with any of this lol, i've never smelt any rotten egg smell, wow... i have no restrictions in the exhaust at all, 2.5" from collector to a JUN muffler, no test pipe, no resignators anything, and i've never smelt anything at all, and i cruise with the window down always, with the heater on as well
the smell of 100 octane is great though i can vouch for that
Old Feb 20, 2006 | 08:47 PM
warwagon's Avatar
i have to simple green mine... mine is so bad both sides of the wing gets coated
Old Feb 20, 2006 | 08:51 PM
Jon D's Avatar
Default Re: Smell after test pipe install (warwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon &raquo;</TD></TR><TR><TD CLASS="quote">
i have to simple green mine... mine is so bad both sides of the wing gets coated </TD></TR></TABLE>
try using Purple Power, i bought it at autozone. That shiz works great. Just make sure you dont let it sit on there too long
Old Feb 21, 2006 | 05:21 AM
jdm_DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">
those black dots are your oil that's burning away </TD></TR></TABLE>
So with a test pipe, will i get more of those dots then, or same amount of oil will pass thru anyways?
djay86
Feb 15, 2005 10:00 PM
io_burn
Nov 12, 2002 07:20 AM
loclowd
Jun 4, 2002 05:01 PM
Snafu-Si
Apr 29, 2002 08:06 PM
Edwin
Aug 9, 2001 05:47 AM
