idle probelm what you guys think?
Old Feb 20, 2006 | 09:15 AM
Race Egr's Avatar
Default idle probelm what you guys think?
ok, the car is a 91 ef dx hatch with a obd1 converted ls swap in it. It throws no cel's. It is idiling very low around 300 and stallin out every once in a while,but it will jump up to normal 750-850 for a minute then go back to almost stalling. It runs like total crap at part throttle major hesistation like its not gettin enough gas. I pulled the plugs and its defintley running lean. I believe there is a problem with fuel delivery. The car has known good injectors we have tried a diffrent map sensor and ecu also none helped. What do u think this sounds like? I plan on checkin the main relay and fuel pressure next as soon as i get a gauge.
millertime191
May 9, 2009 12:28 AM
performanceplus
Aug 30, 2006 08:47 AM
bbrian
10
Feb 22, 2006 08:05 AM
Race Egr
Feb 10, 2006 08:35 PM
jdm.ej
Nov 16, 2005 05:08 PM
