Stock motor swap need help fast
Old Feb 19, 2006 | 08:34 PM
shogun23's Avatar
Default Stock motor swap need help fast
I got an 92' hatch civic cx and my 1.5L stock motor died on me and i got a new motor to put in but my mechnic said it was a 1.6L obd2 motor out of an 97' ek civic. I was told that the motor would work but, I need to do something to a plug to make the motor obd1 and run properlly. Am I right? if so what do I need to do and to what plug? Can't I just drop the motor in and it would run right or no cause it's a cx? Any help would be great thanks
Old Feb 20, 2006 | 07:16 AM
shogun23's Avatar
Default Re: Stock motor swap need help fast (shogun23)
I was also just told by the place that sold me the motor that all I have to do is drop the motor in use my cx harness thats in the car and all plugs up to the motor and what ever plugs are left over that are on the engine don't worry about them also the only thing I have to switch over is the distributor is all this true??? any help would be great thanks
Old Feb 21, 2006 | 07:23 PM
jdmcars.com's Avatar
PM'd
Old Feb 21, 2006 | 10:45 PM
Eman919's Avatar
you going to have to get what you call a jumper hardness from OBD1 to OBD2. You are also going to need the ECU that goes with that D16y8 motor, which i believe is the P2P program.
Old Feb 21, 2006 | 10:48 PM
Eman919's Avatar
You will have to changer your distributor. The one of your Cx is non-VTEC. You should have gotten the Y8 distributor with your MOTOR...........
Old Feb 21, 2006 | 10:50 PM
Eman919's Avatar
It will be very difficult to use your CX hardness. You would have to custumize the plugs so that they fit. To tell you the truth...it's a headache to match the sensors wiith the ECU, I wouldn't take that route. that easiest way is to get that OBD2 to OBD1 jumper.
Old Feb 21, 2006 | 10:53 PM
Eman919's Avatar
If you want to convert your CX hardness...let me KNOW...i can help you out. Hope you got the tranny with that motor too!!!
Old Feb 22, 2006 | 08:37 AM
shogun23's Avatar
Default Re: Stock motor swap need help fast (Eman919)
no i didn't get the trans. just the motor. Alot more people said the same as you so im going to take back the motor cause i found a better motor in better shape with 15k on it. its the reg. cx motor thank so much for the advise
boyds37
Feb 3, 2010 07:03 PM
Ryanwill86
48
Oct 11, 2008 04:33 PM
hondanut
14
Sep 8, 2007 09:25 AM
SlippylesKB
Apr 11, 2003 11:40 AM
