---i felt in a huge hole my car is now drifting to the right side in straight roads---
the car now pulls very badly to the right side, could i have broken something when i felt in the hole or do i just need a wheel aligment
pray for just allignment<<(cant spell
) cause big hole + 2000+lb car =f*ing ur **** up. good luck.
damm i just hope my rims r not messed up as well. i just got some civic si rims yesterday, and today my first day driving them i fall in a huge hole, it was so hard that the tires just popped it was instantly blown, hopefully the rim wont be bent. i seem to have the worst luck
you can do your own visual inspection for anything obviously bent (control arm, subframe, radius rod, whatever). but you need to get an alignment done and see if they can get everything back to spec. if not, then something is bent and needs to be replaced. if its fine, then no big deal.
if your control arm isn't bent, it is likely just in need of an alignment...hard to gauge for us tho, is it swaying violently?
rotascircuit
29
May 1, 2009 09:00 PM
