change my oil
Old Feb 19, 2006 | 04:58 PM
sixtodc2's Avatar
Default change my oil
well today i change my oil wut type of oil do u put in the car ,, i have an 01 integra .. do u put 5-30w or u place 10-30w i am confused
Old Feb 19, 2006 | 05:04 PM
Tornadom's Avatar
Default Re: change my oil (sixtorice)
I always use Mobile One Synthetic 5w-30. You can also run 10w-30 depending on your weather. If it is cold where you live, then stick to the 5w-30.
Old Feb 19, 2006 | 05:13 PM
HB VTEC's Avatar
5w30
Old Feb 19, 2006 | 05:25 PM
sixtodc2's Avatar
Default Re: change my oil (Tornadom)
well yeah i live in cali .. i place Synthetic .. 10w-30..
KaBlookie's Avatar
Default Re: (electronbluehatch)
the first oil change I did after I got my car (last summer) was with Mobil One synthetic and it was 10w30, and there was a little difference from before, but like 2000 miles ago I put in 10w30 Amsoil synthetic and that stuff f-ing rocks! the engine is noticeably (not a lot) smoother and a since then I gained a couple avg mpg
my .02
Old Feb 19, 2006 | 07:24 PM
.one lane's Avatar
.likes trains
Mobile One Synthetic 5w-30. In a 200k motor
Old Feb 19, 2006 | 07:38 PM
mrdeadman's Avatar
They let me pick
not trying to jack this thread but do any of you use that royal purple stuff? is that any good or just overpriced/rated.
Old Feb 19, 2006 | 08:22 PM
numbnuts22715's Avatar
I use Castrol Syntec, mostly cause its a little cheaper than mobil 1...
I use 10W-30 and Im in houston.
Old Feb 19, 2006 | 08:33 PM
RenzoDaPlayboi's Avatar
Default Re: change my oil (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">not trying to jack this thread but do any of you use that royal purple stuff? is that any good or just overpriced/rated.</TD></TR></TABLE>
i use it...my DA runs good wit it
Old Feb 19, 2006 | 09:13 PM
vinai's Avatar
Default Re: change my oil (RenzoDaPlayboi)
I've just started using 0-40 Before you jump on me read the article by bob
http://www.bobistheoilguy.com/
So far I like it and it does not degrade as fast as when I was using 5w-30. I drove from Portland OR to L.A. and the oil still looks pretty fresh considering the distance of the drive. I am still on the same oil change. I am very pleased with this. I can't find the exact article but if you want it let me know or I'll just post it when I find it
Old Feb 19, 2006 | 09:27 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I would only run 10-30 if you lose a little oil with the 5-30 (thinner). If you don't lose any with the 5-30, stick to that.
I used to use 10-30 in summer and 5-30 in winter, but last year decided to just stick to 5-30 all the time. I've been running Valvoline MaxLife 5w-30 for over 100K miles now, engine now has 224,xxx miles on it and runs like a champ.
Old Feb 20, 2006 | 07:58 PM
NuclearB18B's Avatar
Default Re: (PatrickGSR94)
i just switched from castrol high mileage 10-30 to royal purple 10-30. i cant honestly say that i noticed any difference. i have 175000 on my motor and it runs like a champ too. about to be boosted again
Old Feb 20, 2006 | 09:21 PM
SlamminS85's Avatar
Default Re: (NuclearB18B)
honestly if you have a lot of miles on your car and you just got it and this is your first oil change in it, you cant just put in a high grade synthetic, there is a chance ofit slipping past the pison rings and getting burnt up, you shoudl start out useing a conventional synthetic blend and from there you can use high mileage synthetic before useing something like Mobil 1
Old Feb 20, 2006 | 09:23 PM
bks84's Avatar
Loved
honda recommends 5w30...
Old Feb 21, 2006 | 12:04 PM
DJ_Goat's Avatar
I've been using 10w-30 and maybe it looks like I've been burning a decent amount fairly quickly, but I live in AZ so maybe the heat will make a little difference but not too much.
Old Feb 21, 2006 | 01:10 PM
Uncle Willie's Avatar
well since your car is still relatively new, i would go with a synthetic oil now rather than waiting. The longer you wait, the more buildup there is that will be sticking to the gaskets which prevents leaks. So if you switch to synthetic later on, it will clean out all the buildup/sludge and cause it to leak. So get a synthetic oil; it doesnt have to be mobile one, but one you can afford. (except pennziol...i wouldnt even throw that **** in my lawnmower)
Razor
May 8, 2002 04:20 AM
Chip398193
Mar 18, 2002 04:06 PM
nutsack
Sep 5, 2001 11:13 AM
Roadrnnr
Sep 5, 2001 06:31 AM
G2_Integ
Aug 11, 2001 09:13 AM
