99 h22a4 in 98 accord problems
Old Feb 18, 2006 | 06:05 PM
jellyroll's Avatar
Default 99 h22a4 in 98 accord problems
Everythings is good no codes no check engine light nothing. The timing is off according to the timing light the engine won't idle down everything seems to be top dead center even if it was off a cog it shouldn't idle high like that. What could it be>? the car seems to run good like when you get on it could it be a falty distributer or what the deal is. everything was wiried by rywire??
Old Feb 19, 2006 | 06:52 AM
2001accord's Avatar
Default Re: 99 h22a4 in 98 accord problems (jellyroll)
I am not sure if you have one, but i remember my toyota truck was doing the same thing, but anyway try checking your idle control screw on your t-body....there should be 2 screws and you can turn it to adjust the idle.
accord 2 door
Aug 15, 2011 05:55 PM
matt_in_sd
Feb 6, 2005 11:58 PM
1965cat
Sep 28, 2004 08:13 AM
