Need Help: D-series Cable Tranny Experts Needed
Old Feb 18, 2006 | 05:33 PM
godruler's Avatar
Default Need Help: D-series Cable Tranny Experts Needed
hey guys,
i've got an '88 Si tranny thats been in pieces for a year, but its pretty much in good shape for the most part. the case on the other hand has some issues. Any how i'd really like to get Si gearing into my crx because i swapped a d15b7 3 months back but have been still using my HF tranny making the swap almost pointless and now my throw out bearing is going bad. my question i believe the differential bearings on the Si diff are bigger than the HF ones so can i swap the Si ring gear onto the HF diff and how possible would it be to just swap the Mainshaft/countershaft assembly from the Si tranny directly into my Hf tranny, are the bearings on the shafts the same size i know about the spline count difference on the main shaft, but are the shafts different diameters? if i can not do this i need to use my SI tranny case which needs a speedo gear and sensor, shift fork and shift fork rod. could i take these parts from my HF tranny and put them in the Si case to make it work? sorry if this is hard to follow but i'd really like to get this done, the i want to put a stick of dynamite in my Hf tranny cause it sucks fat ***.
thanx
Old Feb 19, 2006 | 07:16 AM
godruler's Avatar
Default Re: Need Help: D-series Cable Tranny Experts Needed (godruler)
no help?
Old Feb 19, 2006 | 08:21 AM
kine462's Avatar
the hf counter shaft will not jive with the si ring gear, I have 2 88 si tranny's if you would like to buy one
Old Feb 19, 2006 | 08:32 AM
godruler's Avatar
Default Re: Need Help: D-series Cable Tranny Experts Needed (kine462)
thats not what i wanted to do, i wanted to put the Si ring gear on HF differential and put the Si main/counter shafts into the HF case. the reason i can't just put the SI diff into the HF case is the Si diff bearings are bigger. MY question was will the SI shafts fit no problem into the HF case.
Old Feb 19, 2006 | 03:51 PM
godruler's Avatar
anyone else
Old Feb 20, 2006 | 08:30 AM
godruler's Avatar
70 views, 1 reply, to that
Old Feb 20, 2006 | 10:06 AM
Tyson's Avatar
your first post is really hard to read. its a lot of babble quite frankly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godruler &raquo;</TD></TR><TR><TD CLASS="quote"> MY question was will the SI shafts fit no problem into the HF case.</TD></TR></TABLE>
yes, it all fits. just keep the final drive and counter shaft together.
Old Feb 20, 2006 | 02:27 PM
godruler's Avatar
Default Re: Need Help: D-series Cable Tranny Experts Needed (Tyson)
thanks man, that was the good news i was hoping to here. sorry for the confusing post
AZTEKEF9
15
Dec 10, 2004 06:39 PM
airikkCRX
Apr 14, 2004 06:07 PM
ceLtic
Apr 6, 2004 05:52 PM
audioroach
Nov 18, 2002 09:07 PM
