master cylndr. (clutch) help
Old Feb 18, 2006 | 05:14 PM
DrivinVtec's Avatar
Default master cylndr. (clutch) help
well i recently replaced my clutch when i took the motor out. i had to refill the master cylndr. back up. i rebleed the lines an called ita day. but it seems i might have a leak somehwere. i MC was really low an even my clutch pedal stuck to the floor twice so far. i dont see any leaks anywhere. i check under the dash by the pedals an at the slave. everything seems to be good, no fluid. any ideas?
Old Feb 18, 2006 | 05:34 PM
roller3804's Avatar
Default Re: master cylndr. (clutch) help (DrivinVtec)
Make sure you bled it well and got all the air in the lines out. You would be suprised how air can stay in there. Alot of times either cylinders can have a leak that is not visible cause the boot is hiding it. Did you buy new slave/master when you put the car back together? Also check where the lines meet with the C clips and such. Its not to hard to get it on the wrong way and have it leak.
Old Feb 18, 2006 | 05:42 PM
DrivinVtec's Avatar
no i didnt replce them. i taken the motor back out here shortly...ill od it then. ill check out the lines...thax
SICCF22
Jul 30, 2011 01:40 AM
FRKWOO
Apr 5, 2009 03:58 AM
92GSR HB
Sep 29, 2008 01:36 PM
GraphiteMW
Mar 25, 2007 09:26 AM
civiceg500
18
Aug 16, 2004 06:11 PM
