CEL throwing a CODE "0" = bad ECU?
not to long ago my dizzy messed up throwing its code. i fixed it. reset the ECU and went back to check the code again. this time it gave me a STALE CODE. when i turned the ignition to ACC. it just stayed on. and no blinks or anything. which i am assuming it is a code 0. my vtec doesnt pop as hard as it used to. even after advancing my timing it popped just a bit harder but not like it used to. so yesterday i bought a p13 spoon ECU *yes its authetic chip* vtec x-over at 5k-8,500. i feel more kick in this ECU but it still doesnt seem to make a big difference. and just right now i checked my codes to see if its still a CODE 0 and it still is. since i changed my ECU, what other possibilities should i be looking for as well? thanks guys!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_lover »</TD></TR><TR><TD CLASS="quote">bump, i tried putting my old ecu and my car still wont start</TD></TR></TABLE>
Don't bump old threads.
You most likely have a problem elsewhere, check around.
are one of the prongs missing where the harness plugs in to the ecu. it has happened
https://honda-tech.com/zerothread?id=2161432
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">Now were making progress. Almost a 2 year old post. I sure hope this guy fixed this by now</TD></TR></TABLE>
hah... he sold the car almost a year ago, now another member has it, and its running strong with no complications... btw.. it wasnt a bad ecu
could this be one of the dummy codes?
