Suspension & Brakes Theory, alignment, spring rates....
Vibration under acceleration!!
Old Feb 18, 2006 | 01:57 PM
matix's Avatar
Default Vibration under acceleration!!
I already searched and just want someone input on this. I just installed my new function and form coilovers. I had shaking under acceleration before this install but was less noticable bc my springs were way softer. Now with the stiff rates its bad. I know its not my motor mounts bc they were replaced when i swapped motors with es inserts. I was wondering if this would cause it. I am almost positive when i had my wheel balanced i had a weight on the outer lip and on the inside lip of wheel. I just checked and the weights that were stuck on the inside of the wheels are all missing. I was wondering if the inside weight falls off would it cause a harsh shaking felt in the steering wheel and floor under acceleration. It also shakes when cruising about 60 mph. Please help thanks.
Old Feb 18, 2006 | 02:25 PM
pingaturbo's Avatar
Could be a couple of things wheels needs balancing, are they after market wheels, also might need hub rings for them, also might be an axle problem, maybe bent wheel etc!!!
Old Feb 18, 2006 | 05:48 PM
DougNuts's Avatar
Default Re: (pingaturbo)
Sounds like a bad axle to me. Exact same symptoms in my buddies Civic.
ohsnapzafingcu
Sep 30, 2012 04:21 AM
gosu08
Oct 22, 2010 09:17 AM
lowtegsr
Mar 21, 2009 03:50 PM
buzlink
16
Oct 18, 2007 07:41 PM
NunRacer
Jul 5, 2002 05:29 PM
