Bent wheel?
Old Mar 21, 2009 | 01:03 PM
lowtegsr's Avatar
Default Bent wheel?
For some reason when i hit a certain speed i get a real bad shake. it feels like my wheel is falling off but there all tight. is there an easy way to check for a bent rim? or any other ideas of what it might be.
Old Mar 21, 2009 | 01:04 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Bent wheel?
Have you had the wheels balanced?
You can visually inspect by putting the car in the air and rotating the wheels by hand. Did you hit some thing?
Old Mar 21, 2009 | 01:43 PM
babiboidb1's Avatar
yeah it might be your wheel balance. Thats usally the prob.
lowtegsr's Avatar
no nothing that would cause it to bend like that
Old Mar 21, 2009 | 01:46 PM
lowtegsr's Avatar
would a bad wheel bearing cause it to shake the whole car at a certain speed?
Old Mar 21, 2009 | 01:52 PM
Dogginator's Avatar
Daisy... Daisy...
A bad wheel bearing would cause issues at all speeds. It usually causes grinding and squealing, but it could vibrate. Put the car in the air and give the wheels the shake test to check the wheel bearings.
Old Mar 21, 2009 | 03:50 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Does the vibration stop if you let off the gas pedal? If so, that's a sure sign of bad inner CV axle joints.
sevwen7
Jun 21, 2011 03:46 PM
()()DC2
Dec 7, 2007 06:45 PM
90efSI
12
Mar 11, 2007 08:53 PM
e g - s i x
Apr 20, 2005 06:14 AM
OneThirtyEight
Oct 30, 2001 06:03 PM
