VTEC noise?
Old Feb 18, 2006 | 11:53 AM
masteryoda10's Avatar
Default VTEC noise?
Should there be a sound difference when my VTEC engages? I have an f22b1 accord and there is no sound change. Could this be because my VTEC doesn't work? In my friend's h22 prelude, you can hear the VTEC clearly.
Old Feb 18, 2006 | 01:21 PM
philadd's Avatar
Default Re: VTEC noise? (masteryoda10)
Man, does this get asked often...
No, you will not hear it. Different engines, different purposes for VTEC, SOHC VTEC only on the intake cam, DOHC VTEC on both intake and exhaust, variable engagement points for SOHC as opposed to set engagement points on DOHC....
Get an intake, and maybe you'll hear it.
Old Feb 18, 2006 | 03:41 PM
XzIpK's Avatar
Default Re: VTEC noise? (philadd)
http://media.putfile.com/Camera-under-Hood
I set up my digi cam in my engine bay out of curiousity. At 38seconds you can hear me starting to accelerate, and at 41 seconds SOHC Vtec engages. Nothing special, but better than nothing. (This is on a 6th gen F23 accord)
Old Feb 19, 2006 | 08:00 PM
Superorb's Avatar
you shouldnt be able to hear it. if you have an intake and you THINK your vtec engages at 4k rpms you are wrong, no matter how cool it sounds. f22b1 vtec is form 2300-3000 rpms based on a whole slew of parameters being met.
Old Feb 19, 2006 | 09:50 PM
philadd's Avatar
Default Re: (Superorb)
actually, the range is 2300-3800.
Old Feb 20, 2006 | 06:37 AM
Superorb's Avatar
i could have sworn my shop manual said 2300-3000.. i'll check it later
Old Feb 20, 2006 | 06:43 AM
Superorb's Avatar
ok here it is straignt from my helms, so we were both a little off
Old Feb 20, 2006 | 08:35 AM
philadd's Avatar
I stand corrected.
I thought it was the same as 6th gens, although I can't remember why I thought that.
Old Feb 20, 2006 | 08:46 AM
Superorb's Avatar
did you know that on the acura cl's they have 160hp as opposed to the 145 the accord ex has? i didn't know that... cant remember if it was the f23 or f22 though...
Old Feb 20, 2006 | 09:32 AM
philadd's Avatar
160? That's gotta be a misprint or something.
The '97 2.2 CL (F22) had 145 hp, 147 ft-lbs. This was the first year for the CL.
'98 saw the introduction of the F23, and thus it became the 2.3 CL. The engine produced 150 hp and 152 ft-lbs.
'99 saw no engine change. This was the last year for this model.
The next CL was in '01, and they only came with the 3.2L V6.
Old Feb 20, 2006 | 10:10 AM
Superorb's Avatar
i heard somewhere it was 160, ill look into it..
Old Feb 20, 2006 | 01:45 PM
philadd's Avatar
Look on edmunds.com. I'm sure it will confirm the numbers I have given you.
Old Feb 20, 2006 | 01:50 PM
Superorb's Avatar
yup, you are correct yet again. 150hp. not too sure where i heard the 160 from though.
Old Feb 20, 2006 | 03:24 PM
mac_24_seven's Avatar
So my Vtec light isn't lying after all!
Depending on throttle pressure, it comes on anywhere from 2500-3500, from what I've seen.
My wife swears she can feel it, I say shes full of it. I can't feel OR hear anything.
The only thing I hear is at 5500 RPM the engine pitch changes drastically: gets much higher. Sounds very cool.
I have an AEM CAI also.
Old Feb 20, 2006 | 03:27 PM
Superorb's Avatar
people that have aftermarket intakes seem to swear that their vtec kicks in at whenever just cause it changes note as it's revving. it isn't due to vtec. single cam vtec doesn't work the same as dual cam vtec does, which you can hear the crossover point.
Old Feb 20, 2006 | 05:37 PM
RnEpmc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac_24_seven &raquo;</TD></TR><TR><TD CLASS="quote">
The only thing I hear is at 5500 RPM the engine pitch changes drastically: gets much higher. Sounds very cool.</TD></TR></TABLE>
sri here.... can anyone clearify that sound. what is happening? sounds very cool. too bad it only last for a second in first and i hate to speed so i rearly hear it in 2nd gear.
Old Feb 20, 2006 | 05:45 PM
philadd's Avatar
I'm going to sound like a ricer for saying this, but I can definitely hear my VTEC engage. But, (yes, there's a "but") I can only hear it during situations where it engages below 3000 rpm, especially at 2300. Above 3000, nah, I can't really hear it.
Anyway, you can hear it more on DOHC motors for 2 reasons:
1. More aggressive timing and lift on DOHC motors (for performance), whereas SOHC have a "mild" setup with more economy and efficiency in mind, rather than performance.
2. DOHC VTEC affects both the intake and exhaust cams, instead of just the intake cam on SOHC motors.
Old Feb 20, 2006 | 06:15 PM
Superorb's Avatar
i wasn't able to hear it at all until i put the p28 in my car with vtec staticly set at 2800 rpms. if i shift early into 2nd gear i can hear the change at around 2800, but this is only sometimes. hard to explain.
Old Feb 21, 2006 | 11:22 AM
mmmsushi's Avatar
look in some other places before saying something stupid
RGK500
Honda Civic (2001 - 2005)
13
Sep 23, 2006 01:05 PM
sohcvtec97
Oct 3, 2005 12:37 AM
billyvalo
Aug 30, 2004 09:34 AM
JMD
18
Jun 6, 2003 10:23 PM
ITR1071
11
Sep 19, 2002 11:49 AM
