I need help
ok i have the hf manifold w/ a custom adapter plate with a 14b eclipse turbo i have to remove my power steering because its in the way of the turbo
what should i do??
get manual steering rack off of a cx?
plug up existing rack?
get a power steering removal kit??
what should i do??
If the motor is in then it will be a bitch job to put a manual one. You could loop the PS lines. I would do it right the first time and replace it with a manual one though.
no it wont mess it up. a lot of people do it .https://honda-tech.com/zerothread?id=184202 check out the write up someone did on it. it will give you some more clarity of the subject
TurboEK9Coupe
Sep 28, 2008 04:29 PM
usdmEHboy
Jan 30, 2007 03:42 PM
exotik4doorcivic
Feb 18, 2006 12:22 PM
1337 Si
23
Apr 9, 2004 12:25 PM
