JDM SIRII caliper replacment (searched)
Old Feb 17, 2006 | 04:22 PM
ABK's Avatar
ABK
Default JDM SIRII caliper replacment (searched)
I need a replacment for JDM SIRII (EG6) caliper replacment. What USDM caliper will work?
Old Feb 17, 2006 | 05:00 PM
Luserkid's Avatar
Default Re: JDM SIRII caliper replacment (ABK)
Isnt that the same bakes as the si?
Old Feb 17, 2006 | 05:19 PM
ABK's Avatar
ABK
Default Re: JDM SIRII caliper replacment (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Isnt that the same bakes as the si?</TD></TR></TABLE>
I don't think so. I think I had to use brake pads of a del sol (don't remember which one, possibly 97). I tried SI, GSR, LS, and other pads. Only one worked. The thing is that I need to get a caliper, but I don't know which one to get.
Old Feb 17, 2006 | 05:21 PM
Luserkid's Avatar
Wow really? Hmm.... always thought it was the same. If something is wrong with the caliper you know you could get it rebuilt right? In a situation like this thats probably what i would do. Food for thought.
Old Feb 17, 2006 | 05:27 PM
ABK's Avatar
ABK
that caliper is fucked. In needs to be honed. There is no way you can fix it without spending some serious dough. I would be cheaper just to change brakets and run GSR calipers.
Only people that rebuild calipers these days are the old school muscle car guys that try to keep the car original.
Old Feb 17, 2006 | 05:37 PM
battle951sedan's Avatar
what size rotors? if u have the 10.3" rotors upfront then that would be similar to any DC(except typeR)brake caliper or any 92-00 civic EX/Si caliper.
if u have the 11.1 inch rotors then that would be typeR calipers that can go over it.
what does the numbers on your calipers say? 17CL14VN are GSR/EX/Si ones. the ITRs have 17CL15VN with the 23T bracket
Old Feb 17, 2006 | 05:51 PM
Sliced Beard's Avatar
Default Re: JDM SIRII caliper replacment (jdm951EK4)
the SIR has the same calipers as the 94-95 Civic EX with ABS.....or 96-97 Del Sol VTEC
problem solved, have a nice day......you can ask anytime.
Old Feb 18, 2006 | 07:55 PM
ABK's Avatar
ABK
Default Re: JDM SIRII caliper replacment (DirtySol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">the SIR has the same calipers as the 94-95 Civic EX with ABS.....or 96-97 Del Sol VTEC
problem solved, have a nice day......you can ask anytime.</TD></TR></TABLE>
yeah thanks alot man. I thought that they were of a del sol vtec 96-97 because that's the pads that I used, but I wasn't sure if the calipers would bolt up to those brakets. I would have to special order those, and if I was wrong I would be fucked again.
Thanks again.
Old Feb 18, 2006 | 07:59 PM
they are actually the same dimensionally as the GSR calipers but there is a small tab that gets int he way of installing GSR pads
Vspronk
Aug 28, 2015 11:56 AM
JDM KILLER
Aug 29, 2009 06:22 PM
93SIRII
Mar 5, 2007 04:51 PM
deadlock32
Aug 25, 2006 10:32 AM
TXDelSol
22
Feb 18, 2003 07:24 PM
