NEED HELP! Dizzy problems/not starting
Ok here's the simple version: so I changed my dizzy with another. Wouldn't start, so put the one on that I took off (was working fine yesterday) still won't start... what the hell how is the possible? Someone please help I need my car to run, and uhm.. its not? someone said turn the part of the dizzy that connect to the cam around 180 degrees, but it won't go on that way so that's no help...
****EDIT 2/22*****
Ok new starter didn't do ****. So we determined I'm getting great spark, and fuel. When you crank it and hold the gas the motor def. breathes and you can her it like very lightly coughing kinda, but no start. Any more ideas?
Modified by xkagax at 9:35 PM 2/21/2006
****EDIT 2/22*****
Sounds like it's your ignitor. . .
But before we jump to that, what are the symptoms? Is your car turning over? Are you getting spark? Is you fuel pump working? Possibly your main relay has gone bad.
my car is doing the exact same thing. i replaced my distributor 2 months ago and it just went out(AGAIN). so i pulled it off figured out i couldnt get it tested so i put it back on and it ran perfect. now that its parked in my garage it wont start again? this just a bunch of bad luck?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ooS710 »</TD></TR><TR><TD CLASS="quote">Sounds like it's your ignitor. . .
But before we jump to that, what are the symptoms? Is your car turning over? Are you getting spark? Is you fuel pump working? Possibly your main relay has gone bad. </TD></TR></TABLE>
it like turns over once, then just makes some weird like grinding sound like its trying to start but won't. How do I test for spark? And no main relay is fine I tried my friends. I dunno it doesn't seem like it'd be the dizzy, I have two and neither one will work...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top »</TD></TR><TR><TD CLASS="quote">the grinding sounds like your starter.</TD></TR></TABLE>
well now its not grinding or making any noise at all.. so I took out the starter and had it tested at autozone.. nothing. A new one gets here on Monday so I hope this fixes it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkagax »</TD></TR><TR><TD CLASS="quote">
well now its not grinding or making any noise at all.. so I took out the starter and had it tested at autozone.. nothing. A new one gets here on Monday so I hope this fixes it.</TD></TR></TABLE>
nothing wrong with it?
or its producing nothing?
Ok I got a new starter, still nothing. I'm getting spark and getting fuel.. so its the dizzy I guess??? I'm gonna work on taking the guts out of my stock d16y7 dizzy and puttin them in my GSR dizzy.. will that work?
dmpd_ef
Oct 25, 2007 06:41 PM
FourthGenHatch
Mar 11, 2003 11:40 AM
