Idle low from power windows
Old Feb 17, 2006 | 10:21 AM
kornerk12's Avatar
Default Idle low from power windows
When i roll my windows up my idle drops and when my windows are closed if u hit the up button on the window the idle will drop. Any ideas ?
Old Feb 17, 2006 | 10:25 AM
syntax.'s Avatar
Default Re: Idle low from power windows (kornerk12)
Thats pretty normal.
The only thing that might help a little would be cleaning out the eacv (iacv) on the intake manifold. Its job is to regulate idle based on electrical loads.
Hope that helps
Old Feb 17, 2006 | 10:40 AM
TheRoyalKannon's Avatar
yeahhhhhhhhhh the same thing happens to me, but only when I'm turning my steering wheel. like if I'm parked & I'm warming up my car & I turn my steering wheel, my idle drops... is that normal too?
Old Feb 17, 2006 | 10:54 AM
syntax.'s Avatar
Default Re: Idle low from power windows (TheRoyalKannon)
yeahhhhhhhhh, thats probably the same thing.
Any electrical load on the engine will cause the idle to fluctuate slightly. The job of the eacv is to compensate for that extra load by adjusting the idle.
bottom line, i wouldnt worry too much about it.
Old Feb 17, 2006 | 10:58 AM
plikit's Avatar
Default Re: Idle low from power windows (syntax420)
yup yup, mine does the same with the power steering
93egboosted
Sep 19, 2015 03:03 AM
mikeunreal2
11
Mar 23, 2006 12:00 PM
sociald
Nov 19, 2004 08:57 PM
mitch529
Feb 21, 2003 11:38 AM
