vtec ecu
Old Feb 17, 2006 | 10:14 AM
JDubbs99Civic's Avatar
Default vtec ecu
ok, so i have a 99 non-vtec motor (d16y7). i did a mini me swap and bought what i thought was the right ecu. apparently not. supposively i bought the vtec ecu from 96-98? and there is another vtec ecu from 99-00? i thought they were all just d16y8's and had the same ecu? i looked on ebay and found a couple of ecu's that said they were for 99-00 vtec and i found 2 different serial numbers on those ecu's. please please please help me find the right one if anyone is familiar with this. heres the two serial numbers i found:
37820-P2T-A11
37820-P2P-A12
Old Feb 17, 2006 | 10:16 AM
snatch's Avatar
Default Re: vtec ecu (JDubbs99Civic)
P2P is the D16Y8 SOHC VTEC EX ECU, I'm not sure about the 96-98 and 99-00.
The P2T is for a 99-00 Civic SI B16A2 I believe.
Old Feb 17, 2006 | 10:18 AM
snatch's Avatar
Default Re: vtec ecu (******)
I found someone that stated their 2000 Civic EX ECU was 37820-P2P-A12
http://www.superhonda.com/foru....html
Scroll down to the bottom of the page.
Old Feb 17, 2006 | 10:32 AM
i also just found one that says its from a 97 and the serial was 37820-p2p-a33, could these last 3 numbers just be from the different years? maybe the old ecu i bought didn't work because it came from an A/T or something?
Old Feb 17, 2006 | 10:33 AM
can anyone confirm that as long as i have a P2P ecu and its for a M/T that it will work no matter what year?
Old Feb 17, 2006 | 10:39 AM
snatch's Avatar
Looks like the 37820-P2P-A33 came from the 96-98 Civic EX's.
I would get one from 99-00 if you could, and get M/T if that's what you have or you will have problems. 96-98 was OBD2a and 99-00 was OBD2b obviously, so there might be some differences between the two ECU's.
What ECU did you buy at first?
Try and find the 37820-P2P-A12
Old Feb 17, 2006 | 10:54 AM
db8gsr_teg's Avatar
Just buy the odb2b to obd1 conversion ($100, i think) and then buy a p28, later on you can get it chip it if you want
Old Feb 17, 2006 | 11:22 AM
Relic1's Avatar
99-00 versions are OBD2b
96-98 versions are OBD2a
you want the OBD2b version to plug into your car.
P2P-A01 - 96 EX sedan manual
P2P-A03 - 97 EX sedan manual
P2P-A12 - 99-00 EX coupe/sedan manual
P2P-A33 - 96-97 EX coupe manual
P2P-A34 - 98 EX coupe/sadan manual
Old Sep 15, 2023 | 09:28 PM
SavetheSOHCs's Avatar
Yessir I have a 98 ex manual and I have the P2P -A34
Throwdown
Jun 8, 2006 07:16 AM
fathergoose
Jan 9, 2006 03:42 PM
snouka
18
Jun 18, 2005 05:39 AM
vizeta
Aug 24, 2004 01:32 PM
Dark Angel EK
Sep 4, 2002 03:36 PM
