eliminating one of my o2 sesor
Old Feb 17, 2006 | 09:24 AM
dohc_ms55112's Avatar
Default eliminating one of my o2 sesor
i just got a custom downpipe made for my civic with 2 o2 bungs. some guy at a local shop told me that i shouldnt keep both of my o2 sesors. If i unhook one of them isnt that gonna cause a check engine light. My car is turbo and i eliminated the cat. I need more info
Old Feb 17, 2006 | 09:26 AM
Relic1's Avatar
if you install both O2 sensors it will set the CEL also.
without a cat the car will see almost identical readings on the O2 sensors and set the cat code.
An O2 simulator is your best bet for the secondary (rear) O2.
Old Feb 17, 2006 | 09:35 AM
snatch's Avatar
Default Re: (Relic1)
Or a different ECU.
Old Feb 17, 2006 | 09:42 AM
Default Re: (******)
how much would the o2 simulater cost and where could it from,the place where i got my dp made just blocked off my rear o2 and told me just to cut it. Im running a vafc 2,dsm450cc injectors and a walbro 255 for my fuel managment on my setup
Old Feb 17, 2006 | 09:56 AM
Relic1's Avatar
if you can run a soldering iron you can make one for ~$12.
http://www.mkiv.com/techarticl....html
If not, you can buy one for ~$30-40.
http://www.casperselectronics.com/
or any other one you can find with google. (search: O2 simulator)
Old Feb 18, 2006 | 11:19 AM
thanks i bought the parts for it.
AGENT 99
Mar 5, 2006 09:46 AM
spoon23_JDizM AkA SpOoN20
Dec 12, 2004 08:26 PM
silver4
May 1, 2004 11:12 AM
ebp 99 si
Nov 4, 2002 02:40 AM
R-1303
Jun 26, 2002 06:22 PM
