fully built ls vtec turbosetup in a 94 ls converted to 98 super clean!!
Old Feb 17, 2006 | 08:20 AM
BIGDADDY-R's Avatar
Default fully built ls vtec turbosetup in a 94 ls converted to 98 super clean!!
ls block w/ godzilla ge sleeves
eagle rods
arias pistons
prodrive oil pump
honda factory bearings and rings
kg engineering ported gsr head
supertech valves
skunk 2 springs and retainers
usdm type-r cams
jg cam gears
type-r valve cover
fullrace exhaust manifold
custom 3" downpipe
custom 2-1/2" charge pipes
750hp rated spearco intercooler
62-1 turbo
1000cc injectors
golden eagle fuel rail
aem pressure regulator
revhard intake manifold
72mm rpm throttle body
tial 44mm wastegate
tial 58mm blow off valve
custom waste gate dumptube
custom 3" exhaust
prodrive4.73 final drive
quaife diff
ls tranny case
brembo rotors
ceramic pads
stainless brakelines
skunk2 coil overs with drag launch rear springs
tokico 5 way adjustable shocks
energy suspension master kit w/ rear trailing arm bushings
brandnew 15" satin black motegi tracklights
195 50 15 falkin azenis
245 60 15 bf gforce drag radials
aem engine management w/ the built in uego wide band this is the top dollar aem list for $1800 to $2300 depends on who you buy it from
bunch of others i havent listed
this set up is only 6 months old and very very clean in side and out!! motor has approx 600 miles on it and made 420 hp on 91 octane @ 14 psi. race gas @28 psi it is good for 6$#hp
$13,000 obo
p.s i will even throw in a 94 ls chassis with black leather interior, new paint, 98 integra front and rear bumpers, type-r wing and a stereo system it has a 10" kicker comp sub this chassis is just a bonus the setup is what you are paying for
B18Sleeper
Sep 24, 2005 11:02 AM
Phoenix1
Nov 23, 2004 09:24 AM
b18b25psi
Mar 3, 2002 02:11 PM
