timing belt tensioning question
Old Feb 17, 2006 | 07:32 AM
an2ny888's Avatar
Default timing belt tensioning question
helms says to rotate the crank so that the cam sprocket moves 3 teeth, then tighten the tensioner bolt. i did this, but the exhaust side of the belt still flaps around a bit. will rotating it by 4 or 5 teeth apply more tension?
Old Feb 17, 2006 | 07:44 AM
RTW DC2R's Avatar
tighten the tensioner bolt, rotate the crank counter clockwise several times to seat the belt. set cyl 1 to TDC, loosen tensioner, rotate counterclockwise 3 teeth on the cam sprockets, tighten tensioner.
when u rotate the crank COUNTER CLOCKWISE, that will tighten the slack on the exhaust side. if you are rotating it 3 teeth counter clockwise, and then back clockwise, you are gonna create slack on the exhaust side. just rotate it 3 teeth COUNTERclockwise, and tighten the tensioner.
Old Feb 17, 2006 | 03:40 PM
an2ny888's Avatar
Default Re: (RTW DC2R)
what i meant was, would rotating the crank counterclockwise by MORE than the 3 teeth specified by helms result in more belt tension? i was thinking 4 or 5 teeth, insted of just 3
Old Feb 17, 2006 | 03:50 PM
RTW DC2R's Avatar
no, rotating 3 teeth puts proper tension on the belt. rotating past 3 teeth will just rotate the cams and crank 2 more teeth. if you want more tension, try the coat hanger method.
Old Feb 17, 2006 | 04:06 PM
an2ny888's Avatar
yeah i was thinking about doing that coat hanger method. where exactly do i hook the coat hanger to? is this a one man job or do i need a buddy?
Old Feb 17, 2006 | 04:22 PM
RTW DC2R's Avatar
I just hook the hanger in the hole where the spring is attached to the tensioner, I have no spring anyway. BE CAREFUL not to screw up the spring, and if you leave the timing belt covers on, its can be a pita.
I would advise against this method if you are using stock head gasket and have not had the head milled, etc. let the tensioner do the job. if you do the tensioner correctly, it will work fine.
Old Feb 17, 2006 | 04:57 PM
B2FiNiTY's Avatar
I also had a little trouble before and what I did was to follow the helms directions and then after tigtening the tensioner bolt, I hand cranked the crank pulley many times and eventually it tightened up.
neoc03
Jul 8, 2008 09:47 AM
98GSR-Turbo
Feb 11, 2008 02:14 PM
neumonik
Jun 20, 2005 02:43 PM
blackek00
Apr 11, 2005 07:29 PM
vtec69
Jan 16, 2003 10:28 AM
