5lug conversion small problem, gear box bolt/nut! Help please!
Old Feb 16, 2006 | 09:56 PM
hondacivichatch's Avatar
Default 5lug conversion small problem, gear box bolt/nut! Help please!
I have a 1996 Honda Civic Hatchback CX and I am doing the 5 lug conversion from a 99 civic type r. The front is all complete but I have one little problem as you can see in the picture. The nut that is saposed to have a cotter pin going threw it is too far up and I am wondering which one of the three things I sohuld do: (1)Should i just losen it and then put a cotter pin threw (is the tie rod saposed to have movement up and down) (2)Do I need the nut off a 2000 si (3)Do I need a tie rod off a 2000 civic si? If you need more pictures just let me know I really want to do this the right way and not take any short cuts. Thanks guys!
Old Feb 16, 2006 | 10:06 PM
BlueIntegraBoy's Avatar
Default Re: 5lug conversion small problem, gear box bolt/nut! Help please! (hondacivichatch)
It's too far up because your balljoint is blown. I suggest getting new tie rods.
Old Feb 16, 2006 | 10:14 PM
Default Re: 5lug conversion small problem, gear box bolt/nut! Help please! (BlueIntegraBoy)
Can I just repace the ends of the tie rods? (The casing with all the grease)
Old Feb 16, 2006 | 10:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivichatch &raquo;</TD></TR><TR><TD CLASS="quote">Can I just repace the ends of the tie rods? (The casing with all the grease)</TD></TR></TABLE>
Yup, the tie rod ends you will be replacing.
Old Feb 16, 2006 | 10:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
Yup, the tie rod ends you will be replacing.</TD></TR></TABLE>
So I would need parts 25 and 24?
Old Feb 16, 2006 | 10:52 PM
I would replace the whole tie rod end (#23 & #26)
53540-S04-013 END, R. TIE ROD
53560-S04-013 END, L. TIE ROD
Old Feb 17, 2006 | 12:51 AM
95sihb's Avatar
I would suggest doing what BlueIntegraBoy stated. Just get a new ball joint, it's less messy and it's easier to just have the ball joint pressed out then too try to remove the boot cover and clean the grease .Then , replace the boot and repack it and tie the wire band that holds the boot to the actual ball joint, this sux trust me . So just get part 23 or 26 not sure witch it the side you need, but one it for the left and one for the right.
Old Feb 17, 2006 | 06:21 AM
Default Re: 5lug conversion small problem, gear box bolt/nut! Help please! (95sihb)
Alright thanks guys, I need both sides so I guess I will get both. Thanks again!
jdmb18c-hatch
Suspension & Brakes
Nov 26, 2009 01:06 PM
Presto800
Suspension & Brakes
Jul 18, 2008 08:32 PM
YoungMoneySi
Welding / Fabrication
Nov 9, 2006 02:46 AM
pumpkyn
32
Mar 26, 2006 05:53 PM
jdmxGod
Aug 17, 2005 01:25 PM
