IACV problems relating to weather? (Idle surges)
Old Feb 16, 2006 | 08:42 PM
Mik3's Avatar
Default IACV problems relating to weather? (Idle surges)
Since the weather's starting to warm up here the past few days, my idle has been surging maybe ~500rpms up and down when it's not in gear. Today it was really warm and my idle was jumping up and down...not much but really noticeable to the ear. The tach didn't jump much but you can hear it. I also threw a code 14 (IACV). It also surged in gear when i let the gas off.
Would cleaning the IACV and bleeding the coolant system cure my problem? or do I have other problems? I read the FITV is for when it's cold so it couldn't be that could it?
Sorry if it's been covered but i searched and everyone's idle surge problem was dealing with ~500-1000rpm surges. Mines goes up and down in half second intervals with only like ~100rpm differences.
Old Feb 16, 2006 | 09:25 PM
Mik3's Avatar
Default Re: IACV problems relating to weather? (Mik3)
before sleep bump!
i'm going work on it asap tomrrow or this weekend to see whats causing this idle surge.
for having a shitty 5th gen. one problem after another
Old Feb 16, 2006 | 09:34 PM
robGs-R's Avatar
uhh kinda sorta? put the heat on and sometimes it will lower. if your iac control is going then heres some good adivse. change it. thx for asking plz come again
lude98SH
Dec 16, 2005 01:37 PM
UNKNOWN_MEMBER
Apr 20, 2005 12:39 AM
JFG Kevin
Feb 22, 2004 09:59 PM
TheIntegraGuy
Jan 22, 2004 06:48 PM
