Shifter stuck in park - electrical?? *searched - really*
Old Feb 16, 2006 | 03:11 PM
snakepirates's Avatar
Default Shifter stuck in park - electrical?? *found problem - fixed*
I have this weird problem and i was wondering if anywone could help me out if have heard of somthing like this. I've searched this topic but can't find the answer i'm looking for. The car is my girlfriends 93 civic si coupe - auto.
The car is stuck in park and the brake lights don't work. So first thing I think of is the brake light switch. I tested the switch (with and ohm meter) and it seems to work properly. Just to be double sure i jump the switch with a wire, still nothing. This is where it gets strange. I noticed when i jump the switch (or press the brake pedal with the switch in place) I hear a hissing sound and a burning smell from under the dash somewhere. I should also note that the clock resets itself to 1:00 all the time and i've had to rewire the horn because it also didn't work when she bought the car. No fuses have ever blown either.
If anyone has any input on this i'd appreciate to hear it. I'm just trying to save some time troubleshooting.
Thanks!!
Modified by snakepirates at 4:31 PM 2/20/2006
Old Feb 16, 2006 | 03:26 PM
crazi_E's Avatar
Default Re: Shifter stuck in park - electrical?? *searched - really* (snakepirates)
i think u should get an excorsim on ur car..i think its possesed
Old Feb 16, 2006 | 03:33 PM
postman's Avatar
sounds like a short somewhere
Old Feb 16, 2006 | 04:19 PM
5lugSlug's Avatar
you need new gauge cluster, happened to me
CRISIS's Avatar
I had the same problem in my eg sedan. Turned out to be the fuse in the engine bay. It's for the horn and brake lights. If the brake lights don't go on it won't let the car go into drive. Try it out. Use a 20 amp.
Old Feb 16, 2006 | 04:52 PM
Default Re: Shifter stuck in park - electrical?? *searched - really* (CRISIS)
Thanks for the input guys, keep it coming.
I'll look into the guage cluster idea, havn't thought of that. I can hear a hissing sound and burning smell coming from somewhere under the dash when i jump the switch so somthing is up somwhere. I've checked all the fuses already and everything is fine there. There very well could be a short somewhere but it'll be a pain finding it under the dash (i've checked everywhere else).
Old Feb 16, 2006 | 05:08 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRISIS &raquo;</TD></TR><TR><TD CLASS="quote">
I don't think it's the brake lights as much as the brake sensor, either way, that's worth a try. Though yeah, it sounds like a short, the smell and hissing sound.
Old Feb 16, 2006 | 05:17 PM
Patron's Avatar
it's a fusable link, in your engine compartment, it's probably a big one.
john666's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRISIS &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem in my eg sedan. Turned out to be the fuse in the engine bay. It's for the horn and brake lights. If the brake lights don't go on it won't let the car go into drive. Try it out. Use a 20 amp. </TD></TR></TABLE>
also happened to me when i had auto. its just a fuse.
Old Feb 20, 2006 | 03:24 PM
Default Re: Shifter stuck in park - electrical?? *searched - really* (john666)
found the problem... junction c417 was badly corroded and was shorting out. Cut all the wires and sliced them back together properly. Everything works fine now.
babybreese
Aug 16, 2017 12:33 PM
EG6DGK
Nov 23, 2008 07:05 PM
LSracing94
Aug 30, 2007 09:29 AM
opi8
Mar 14, 2005 10:19 AM
AlxSiR7
Nov 25, 2004 02:12 PM
