valve cover bolt snapped. what can i do??
Old Feb 16, 2006 | 01:37 PM
doggworld1233's Avatar
Default valve cover bolt snapped. what can i do??
the valve cover bolt snapped and what can i do to fix it. it looks like there is some of the bolt in the hole. can i put a new bolt in and will that fix the problem? or leave it like it is. i think it is leaking oil , it is on my hood.
justin
Old Feb 16, 2006 | 01:39 PM
ChicagoMike's Avatar
Buy an EZ out. Pull out the old bolt, put a new one in. Fixed!!
Old Feb 16, 2006 | 01:41 PM
tomu06's Avatar
Default Re: valve cover bolt snapped. what can i do?? (doggworld1233)
go down to honda, its like 5 bux at the most.. the torque on those are really low.. you can't tighten too hard or they snap off like twigs.. just go down there, tell em you need a new valve cover bolt.. they'll show you a picture on the computer.. you tell em the number on the page.. its like $3.50-5 i think.. to change the old one that snapped.. you need to pull your valve cover off.. and the bolt you snapped has either a 10mm or 12mm bolt you need to take off and replace.. really simple good luck.
Old Feb 16, 2006 | 02:28 PM
HXvtec's Avatar
Default Re: valve cover bolt snapped. what can i do?? (tomu06)
i snapped 2 of mine. i just put a bolt in it so oil doesnt spill out. im to lazy to pull it out.
Old Feb 16, 2006 | 02:33 PM
AnToNy's Avatar
Just replaced one of mine. Go to Honda and get one for $6, and it will take maybe 10 minutes to replace. Remember those bolts don't need alot of torque to tighten them
Old Feb 16, 2006 | 02:54 PM
SovXietday's Avatar
Default Re: valve cover bolt snapped. what can i do?? (AnToNy)
Leave the bolt in there until you get a bit of time, this will keep it from spraying oil. Get a new bolt.
When you get time, unbolt the valve cover, and pull it off again. Take a safety pin or something with a very sharp point, some sort of needle. Take the point, and put it in the whole where the bolt snapped. Rotate the pin/needle around in a clockwise rotation around the edge of the threads. You should be able to work what's left of the bolt out. It's how I got mine out when I broke it.
Bolt it back up, making sure to NOT tighten it too hard. The torque specs are 7lbs I'm pretty sure, which is nothing. I learned that when I bolted everything on, and then went around in a circle tightening all the bolts.
Old Feb 16, 2006 | 02:58 PM
CivicBlack's Avatar
All you need is an ez out and a drill. This was a 3 minute fix for me. Just drill a hole down the middle of the broken bolt. Not too big of a hole though. Then take an ez out bit, and tap it into the hole lightly. Then if you are as lucky as i was, you can simply twist the broken bolt out with your fingers.
k_lude
Jan 9, 2007 06:48 PM
murmur9
Mar 10, 2006 05:06 PM
SlowB16si
Jan 28, 2006 02:13 PM
happy_guy
Aug 9, 2005 06:36 PM
LoudAccord
Jan 9, 2003 10:43 AM
