auto to manual swap ?????
Old Feb 16, 2006 | 12:20 PM
supermanvick's Avatar
Default auto to manual swap ?????
i have a 96 civic ex 2dr and i was wondering how difficult it will be to swap my automatic with a manual tranny and i was wondering all i have to do?Expensive?????
Old Feb 16, 2006 | 12:35 PM
93bluehb's Avatar
you'll need: tranny w/ linkage, clutch, flywheel(flywheel bolts, clutch bolts) manual pedal assy(including gas,brake,clutch), clutch lines, clutch master cylinder, slave cylinder. manual ecu. and the time to wire it up.
search the forum their is alot on here about it.
snatch's Avatar
Default Re: auto to manual swap ????? (supermanvick)
Search search search. I know for a fact there is a write-up on here about how to do it, all parts needed, and relative cost of the project. It's not really hard, it takes the better part of a weekend, and it will cost several hundred dollars.
Old Feb 16, 2006 | 12:43 PM
philosofy1's Avatar
if you buy a complete swap, then all you really need left is clutch resevoir, resevoir bracket, master cylinder, clutch lines, clutch pedal, and brake pedal(unless you cut the auto brake pedal in half), and last but not least a auto to manual tranny bracket(trust me i didn't do all my research and this mount set me back a week).
clutch lines you can find easily at a salvage yard. i found mine, pulled it off an integra. paid $10, and that was the complete line.
paid $15 for brake & gas pedal assembly at a salvage yard as well.
it's really not hard, my suggestion to you. put all the clutch hardware in after you rip out the old motor(before installing the new one), it'll be alot easier and alittle stress free.
good luck!
**EDIT** oh yeah don't forget you'll need to wire up the auto shifter so you can start the car.
Old Feb 16, 2006 | 02:44 PM
MonkeyPuzzle's Avatar
I waited till I found a wrecked car with all the parts I needed, then you know you have everything. Then basically just unbolted from one car and bolted onto the other.
Old Feb 16, 2006 | 02:58 PM
haveaniceday's Avatar
Default Re: auto to manual swap ????? (MonkeyPuzzle)
https://honda-tech.com/zerothread?id=1337459
Midori Green
13
Dec 6, 2006 04:56 PM
Jmunk
Apr 1, 2006 05:02 AM
AznInvasion
Sep 12, 2003 06:19 PM
PainfulTeg
Oct 15, 2002 01:46 PM
DevinW
Apr 15, 2002 06:06 AM
