Will the NRG Engine Damper for 96-00 fit 99-00 Si?
Got a kit from a friend, he said it would fit, but one of the reps at NRG said no.
Has anyone mounted one on a 99-00 Si?
No instructions on how to mount either.
Thanks,
Thanks,
those are made for the specific car. ie. 96-00 is for all single cam 96-00 motors. you have to buy it for the car. they are not swap friendly. i am not sure if they make one for the si or not. i have only seen them for d-series motors.
I don't doubt that it will fit, but will the geometry be so off to make it not an effective piece?
It's a support piece with limited effectiveness to begin with. changing the operating angle might change how well it works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aZnjCC »</TD></TR><TR><TD CLASS="quote">didn't i just prove that it 'll fit with my pics?
Yes you did, because the driver side bracket does not change ever unless you get a HAsport mount. Those two holes where the studs come through will always be in the same spot making it easy to bolt up that part regardless. The only part that is required for B-series into EK is the "motor side" engine mount and rear T-bracket.
</TD></TR></TABLE>Yes you did, because the driver side bracket does not change ever unless you get a HAsport mount. Those two holes where the studs come through will always be in the same spot making it easy to bolt up that part regardless. The only part that is required for B-series into EK is the "motor side" engine mount and rear T-bracket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuned2 »</TD></TR><TR><TD CLASS="quote">they break also. anything over 25 at the wheels, kiss it goodbye.</TD></TR></TABLE>
anything over 25?! WTF does that mean?
There are people in the drag-racing forum running 250-300+ and have used these w/o issues.
sicones do a search on 'engine damper' there are lots of decent threads floating around. Alot of poeple have had good results w/ them.
My roomates' NRG Damper broke, and he wasn't even making that much power... He didn't have his upper timing belt cover on, and one of the bolts got down there and shredded up the belt.
So make sure you atleast have your cover on if you put one of these on your car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic »</TD></TR><TR><TD CLASS="quote">My roomates' NRG Damper broke, and he wasn't even making that much power... He didn't have his upper timing belt cover on, and one of the bolts got down there and shredded up the belt.
Ooohhh that sucks. I would be so pissed.
</TD></TR></TABLE>Ooohhh that sucks. I would be so pissed.
Loctite Red is all you need to keep the bolts in.
IMO, the damper's okay. I would just skip it entirely and get motor mount inserts. I'm selling mine because the damper gets in the way of tuning your cam gears. I don't want my tuner to get irritated tuning my car
My motor mount inserts get the job done just fine, without the gay bling.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic »</TD></TR><TR><TD CLASS="quote">or you can pick up some REAL mounts from Innovative, like I just did.
they look nice, but i am a proponent of hasport, been using them for 4 years and never once had a fitment issue.
</TD></TR></TABLE>they look nice, but i am a proponent of hasport, been using them for 4 years and never once had a fitment issue.
Hasport has greating fitting mounts. I got these Innovative ones off ebay for $230 shipped, which fit my budget a little better than Hasports. They fit perfect and I've had them in my car for a day now and the difference is amazing.
GermyLin
13
Aug 22, 2021 09:37 PM
siblue_gzer
Apr 28, 2008 12:06 PM
EricUSC
Jan 25, 2003 12:23 PM
