Swollen coolant hose=bad thermo?
My coolant hose is swollen right where it goes into the thermostat housing and I can see a small drip from under the housing. Also the fans havent been turning on so I am beggining to think the thermostat is stuck shut....any other input? This is on a 91 SI
Well now the fans are working, i unplugged the temp sensors and plugged them back in and now they work.....still havent figured out the steering wheel vibration yet or why i have one dim headlight on high beams lol
the hose doesnt feel bad though, it isnt all soft and stuff. fans finally work though for some odd reason.
I tried swapping the headlights to see if it was the light itself and its not, my dad said its probably the ground wire......now to find that wire
The hoses will deform over time. They're rubber and will do that.
That being said, if it's bulging pretty bad right around the clamps, replace them. If you're too cheap to replace them, wrap the entire sucker in duct tape. It WILL seal it and keep it from blowing for a good long time, and will add a nice space-age shine to your engine bay!
zx92027xz
19
Jan 15, 2014 04:36 AM
