I did a on board test and i'm getting code 15...
Old Mar 27, 2002 | 08:00 AM
91CRXSI's Avatar
Default I did a on board test and i'm getting code 15...
I have a 91 crx si 1.6 and my car is missing really bad at like 4000 rpms. Also the rpm needle is jumping at like 4500 rpms. Ildes perfect, so I'm not sure what to replace. Just did a major tune-up aslo (cap, rotor, plugs, plug wires).
Old Mar 27, 2002 | 08:06 AM
EF'n's Avatar
Default Re: I did a on board test and i'm getting code 15... (91CRXSI)
code 15 is a ignition output signal. you may have to replace your igniter inside your dist. if you need one i have a few laying around. good luck
Old Mar 27, 2002 | 08:39 AM
91CRXSI's Avatar
Default Re: I did a on board test and i'm getting code 15... (revhardracing)
is the igniter like a coil. If that was bad would the car still run good at idle?
Old Mar 27, 2002 | 12:18 PM
Perfectionist's Avatar
The ignitor or coil can fail gradually. At idle and low rpms, the frequency of the spark pulses is low. At high rpms it is of course higher. The higher frequency may be enough to cause a break down in the coil windings.
Old Mar 27, 2002 | 01:38 PM
EF'n's Avatar
Default Re: I did a on board test and i'm getting code 15... (Perfectionist)
your coil is most likley o.k., there is a little brownish like 2"x2" thing in there too, that is the igniter. i think that is your problem, if you dont have a wrecking yard around you that will sell you one for like $5 let me know and i will ship you one out.
bay.kid
Sep 24, 2017 09:46 AM
NIKADEM0
Honda CR-V & Element
Aug 8, 2014 06:28 AM
crexer
Sep 14, 2006 07:36 PM
IWearMyKswiss
Sep 17, 2004 09:49 PM
SOHC_MShue
16
Dec 4, 2003 07:16 PM
