Trouble launching...1st gear keeps popping out!!
Old Feb 15, 2006 | 09:39 PM
blazin99si's Avatar
Default Trouble launching...1st gear keeps popping out!!
Everytime I launch, popping the clutch and full throttle, 1st gear keeps popping out of gear. Have traction bars and motor mount inserts. If I dont hit it full throttle everythings fine but this just recently started happening. 99 Civic coupe, B20 motor, B16 hydro tranny, GSR axles (went thru 4 WEAK-*** B16 axles) Any suggestions??
Old Feb 16, 2006 | 02:37 AM
hondaguyef's Avatar
Default Re: Trouble launching...1st gear keeps popping out!! (blazin99si)
Do a search on the word(s) "Preload, preloading, launching techniques". I've explained it a few times here. If your tranny isn't the issue that should help alot and you'll also stop breaking axles.
Phil
Old Feb 16, 2006 | 05:38 AM
E Town DSM's Avatar
Default Re: Trouble launching...1st gear keeps popping out!! (hondaguyef)
Make sure that u have the little detent ***** on the tranny. Ive seen them pop out due to not having them.
Old Feb 16, 2006 | 06:03 AM
bergenholtzracing's Avatar
Engine mount could be broken.
Motor torques back and pulls it out of gear?????
Old Feb 16, 2006 | 08:21 AM
blazin99si's Avatar
Thanks for all the input guys, really appreciate it
Old Feb 16, 2006 | 08:51 AM
SpeedDreamz.com's Avatar
other than launching does it stay in 1st ok? Feel like it engages smooth? I have seen the same problem and it was internal.
Old Feb 16, 2006 | 12:11 PM
underpressure02's Avatar
Check your tranny fluid had the same problem and the tranny fluid was low. Added some problem went away.
Old Feb 16, 2006 | 02:44 PM
Dragline's Avatar
Default Re: (bergenholtzracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bergenholtzracing &raquo;</TD></TR><TR><TD CLASS="quote">Engine mount could be broken.
Motor torques back and pulls it out of gear?????</TD></TR></TABLE>
^^ Thats what I would think also^^
Old Feb 16, 2006 | 03:57 PM
BlownHatch's Avatar
Default Re: (Dragline)
as said by hondaguyef i would be willing to bet if you preload your problems will go away.i used to have the same problem back before i started preloading.
Old Feb 16, 2006 | 10:10 PM
blazin99si's Avatar
Default Re: (BlownHatch)
Well besides launching it stays in 1st, Im going to check the rear mount and tranny fluid tomorrow but I searched for preloading info and Im still a bit confused. I have Neuspeed sport springs and KYB adjustables. Can anyone school this noob on preloading?
Old Feb 17, 2006 | 12:11 AM
raceACCORDingly's Avatar
Default Re: (blazin99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazin99si &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone school this noob on preloading?</TD></TR></TABLE>
Hold the e-brake up, let the clutch up just enough so you can feel the car pull, while holding the revs at what ever you want to launch at. You drop the clutch and the e-brake at the same time.
Old Feb 17, 2006 | 08:07 AM
blazin99si's Avatar
Default Re: (raceACCORDingly)
Thanks man, real simple no doubt
zoso
Transmission & Drivetrain
18
Oct 23, 2009 04:19 PM
SleepyHatchZ6
16
Aug 26, 2008 08:55 AM
Spoon84
Jan 17, 2006 01:30 PM
TylerC
Jan 5, 2006 10:21 AM
EVIL Hx Coupe
Dec 13, 2002 01:07 PM
