My RPMs are too high
Old Feb 15, 2006 | 08:35 PM
pec pec's Avatar
Default My RPMs are too high
why is it that when im on the highway my car is running on high RPMs and at a low speed i was juss curious
can this possibly b my distributor or spark plugs
thanks
Old Feb 15, 2006 | 08:38 PM
h224thgensedan's Avatar
what gear are you in at what speed and rpms
Old Feb 15, 2006 | 08:40 PM
e jay one's Avatar
Default Re: (h224thgensedan)
more importantly what tranny do you have?
Old Feb 15, 2006 | 08:41 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (e jay one)
if your car is an si then that is the way it is.
to fix it, sell your car and buy a dx or std or hf crx.
Old Feb 15, 2006 | 08:42 PM
Targa250R's Avatar
be professional
Default Re: My RPMs are too high (ef9 562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9 562 &raquo;</TD></TR><TR><TD CLASS="quote">why is it that when im on the highway my car is running on high RPMs and at a low speed i was juss curious
can this possibly b my distributor or spark plugs</TD></TR></TABLE>
No. It's something called "gearing."
Old Feb 15, 2006 | 08:43 PM
e jay one's Avatar
Default Re: (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">if your car is an si then that is the way it is.
to fix it, sell your car and buy a dx or std or hf crx.</TD></TR></TABLE>
haha good idea but then he will be slower. i got a dx tranny in my car and cruising at 80 mph its at 4000 rpm
Old Feb 15, 2006 | 11:11 PM
hondatuner123's Avatar
its called a hf or dx fifth in a si tranny. been there done that. it owns
Old Feb 16, 2006 | 05:41 AM
Targa250R's Avatar
be professional
Default Re: (hondatuner123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuner123 &raquo;</TD></TR><TR><TD CLASS="quote">its called a hf or dx fifth in a si tranny. been there done that. it owns</TD></TR></TABLE>
DX gear ratios are all the same as the Si ratios, with exception of the final drive.
Old Feb 16, 2006 | 05:46 PM
e jay one's Avatar
Default Re: (Targa250R)
why would you waste that much time on a single cam tranny? just curious.
Old Feb 16, 2006 | 05:48 PM
3s0n3's Avatar
a stock 91 si runs 4000rpm at 80-mph ish
Old Feb 17, 2006 | 03:18 PM
Slacker87's Avatar
I have a 1990 crx 1.6 si and im at about 3,200 rpm at 80. It doesn't have a whole bunch of torque but just enough so i dont slow down going up small interstate inclines. 4k rpm sounds high to me. My mods are k&n air filter Strait pipe ,Exaust,
My weighs a ton to. I have atleast a 100lb sound system. Try taking out your cat.... it helped tons in mine
Old Feb 17, 2006 | 03:36 PM
I Have an STD's Avatar
wrenchin'
Default Re: My RPMs are too high (hCrx90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hCrx90 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1990 crx 1.6 si and im at about 3,200 rpm at 80. It doesn't have a whole bunch of torque but just enough so i dont slow down going up small interstate inclines. 4k rpm sounds high to me. My mods are k&n air filter Strait pipe ,Exaust,
My weighs a ton to. I have atleast a 100lb sound system. Try taking out your cat.... it helped tons in mine</TD></TR></TABLE>
you are dumb. you probably have 17s or 18s on there dont u?? thats why ur geared so low on the highways you dumb ****
Old Feb 18, 2006 | 08:05 AM
driveahonda's Avatar
how have you been there done that if that is the same gear????
Old Feb 18, 2006 | 09:30 PM
sanimalp's Avatar
$cat /dev/urandom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hCrx90 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1990 crx 1.6 si and im at about 3,200 rpm at 80. It doesn't have a whole bunch of torque but just enough so i dont slow down going up small interstate inclines.</TD></TR></TABLE>
you must have a dx tranny if you are cruising at ~3200 rpm at 80 mph..
here.. http://crx.honda-perf.org/math/index.html
make sure you select the final drive.. cause that makes all the difference
and here https://honda-tech.com/zerothread?id=1355842
zuviex00
11
Feb 24, 2008 02:41 PM
dillonG_B
Jan 29, 2008 10:29 PM
hmtcrxsir
Jan 4, 2007 11:17 PM
89 civic si
11
Oct 1, 2006 07:51 PM
Rickcrx
Nov 23, 2004 09:19 AM
