Type r parts into EK?
Old Feb 15, 2006 | 04:52 PM
ekim952522000's Avatar
Default Type r parts into EK?
ok guys heres the deal I've got a wrecked 2000 type R and a 97 civic hatch what do i need to put the type r engine in the civic?
Also can I just swap over all the type r suspension, sway bars, brakes, front and rear control arms, and everything else or do i need some thing special?
Thanks for all the help I think I need a Haspot kit and I don't think the sway bars will work let me know if this is wrong.
Old Feb 16, 2006 | 07:08 AM
Terrible One's Avatar
Default Re: Type r parts into EK? (ekim952522000)
you'll need a motor mount kit such as hasport, chipped ecu since the 2000 type r ecu wont plug into your 97 civic, suspension/brakes should fit, rear lower control arms should fit as well
Old Feb 16, 2006 | 08:27 AM
Default Re: Type r parts into EK? (Terrible One)
From my understang i will also need a ex wiring harness and some diffrent fuel stuff not real sure.
On a scale of 1-10 how hard would you guys rate this swap?
Old Feb 16, 2006 | 10:14 AM
take the type r's vtec wiring and wire it up to your civic's wiring harness
Old Feb 16, 2006 | 10:41 AM
EMJAY's Avatar
i planning on doing the same swap. the website below has good info
har bra: http://www.phear7imports.net/trey/6gen/
Old Feb 16, 2006 | 11:43 AM
Default Re: Type r parts into EK? (EK12)
Thanks for the link
OK so if I want to convert to obd1 i need a civic ex ecu and a obd1 conversion harness?
I was also thinking about getting a ecu witha hondata from king I'm trying to make this as bolt in as possible.
I'm trying to confirm that all i need is a ex harness and splice a few wires and im on a running is this correct
Nikademo
Apr 19, 2010 08:02 PM
iheartDc2
Feb 18, 2006 08:02 AM
ekim952522000
12
Feb 15, 2006 08:06 PM
01-1293
Dec 21, 2004 05:21 PM
92integ
Feb 17, 2003 04:55 PM
