Coolant leak !!!!
Old Feb 15, 2006 | 02:52 PM
ahasan's Avatar
Default Coolant leak !!!!
I did a Gsr swap on my civic and now i have a coolant leak from the lower hose. My question is has anyone else has this problem or is there something i can do in order to stop it from leaking.
Old Feb 15, 2006 | 02:58 PM
aquabob89's Avatar
* B A N N E D *
Default Re: Coolant leak !!!! (ahasan)
Is there a hole in the hose?
Old Feb 15, 2006 | 03:28 PM
EX-T's Avatar
What kinda question is this? Just replace the hose and see if it still leaks!
Old Feb 15, 2006 | 03:32 PM
E46Kid's Avatar
Default Re: Coolant leak !!!! (DSeriesBKilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla &raquo;</TD></TR><TR><TD CLASS="quote">What kinda question is this? Just replace the hose and see if it still leaks!</TD></TR></TABLE>
Old Feb 16, 2006 | 04:55 AM
ahasan's Avatar
OK... Maybe I didn't say it but i would assume you would realize I already replaced the hose. Anyway i guess what i am asking is what did you guys do to get the bigger GSR hose to actually get a good seal on the civic radiator...
Old Feb 16, 2006 | 05:04 AM
fakemike's Avatar
I am using del sol (b16) hoses on my gsr swap. Get the sealant that is made to put on the inside of the hose. And don't use the the stock clamps, get some worm clamps. Make sure not to make them to tight b/c you can crack the plastic radiator.
Old Feb 16, 2006 | 05:44 AM
fsufan716's Avatar
get some quality hoses to make sure its the hose if its is then ur problems fixed if not your raditor might be screwed up what radiator did you use
Old Feb 16, 2006 | 07:27 AM
joey1320's Avatar
if you are using the bigger hoses(b series) on the stock civic radiator you can take the old smaller civic hose, cut about 2 inches of it and place it on the neck of the radiator and then put the bigger hose on it.
that way you don't have to use clamps too tight that can damage/crack the radiator. or you can get a b series radiator.
good luck!
Old Feb 16, 2006 | 07:40 AM
ahasan's Avatar
Default Re: Coolant leak !!!! (fsufan716)
I used the 96 civic radiator<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fsufan716 &raquo;</TD></TR><TR><TD CLASS="quote"> what radiator did you use</TD></TR></TABLE>... what year del sol should i get the hose from... If I try it<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fakemike &raquo;</TD></TR><TR><TD CLASS="quote">I am using del sol (b16) hoses on my gsr swap. </TD></TR></TABLE>.
duffman1278
Sep 14, 2008 04:40 AM
obuhmyuh
Feb 25, 2008 04:54 PM
floatfisher
Apr 20, 2007 08:32 PM
s0ulcommited
Oct 14, 2005 06:43 AM
Cypher0117
18
Sep 29, 2005 07:46 PM
