Need help with my idle problem.
Old Feb 15, 2006 | 02:44 PM
krazycueball's Avatar
Default Need help with my idle problem.
i recently did a swap in my 92 civic from a vx to a d16z6.the car idles at 2500 and bounces up to about 3000 rpm. i've checked my IAC, TPS, And coolant and pretty much can only think that it's gotta be a vacuum hose? If you have any ideas please let me know!
Old Feb 15, 2006 | 02:50 PM
pcupo12's Avatar
Vac leaks SUCK. Get some intake manifold cleaner and slowly spray it over the vac lines, if the car boggs down, then you know thats where the leak is. I currently have a leak coming from the Intake manifold gasket, this hondata gasket seems to be taking FOREVER to get here!
Old Feb 15, 2006 | 03:31 PM
EX-T's Avatar
Default Re: (pcupo12)
is it consistently revving up and down?
Old Feb 16, 2006 | 03:56 PM
Default Re: (DSeriesBKilla)
yes it does go kup and down. and when i cover the throttle body my car doesn't die either.
93SiPrelude
Feb 24, 2008 10:39 PM
inane
10
May 19, 2007 05:36 AM
98itr0448
Jul 10, 2004 03:17 PM
rtiadnoh
Feb 15, 2004 12:41 PM
Vp Special K
26
Nov 9, 2003 10:24 AM
