--> Not your average clicking/knocking noise... help!@#
So i've been through the CV axel ordeal with it clicking continously and all... but this one is different.
When i turn left or right, the Driver side Front starts to do LARGE and LOUD >KNOCKINGS< ... enough for the whole car to vibrate and ****. Its like something wants to break but cant... and I notice its ******* with the engine drivability (meaning when it starts to knock, the car actually sounds like its try to catch... but cant... like it would be fine, then the knock would synch with the car being able to drive)
I changed out the axel recently, and it still does the same ****. Im gonna change out the other side for the hell of it since i got lifetime warranty axels.
So basically its not the axels, but the car makes huge knockings that does affect the motors ability to drive and go. Any Ideas?
Maybe low Tranny Fluid?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicilianSpeed42 »</TD></TR><TR><TD CLASS="quote">sounds like it could be your tranny/clutch</TD></TR></TABLE>
OUCH! mmm, im gonna replace the tranny fluid... how much fluid should i put in a Si tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST »</TD></TR><TR><TD CLASS="quote">what axles (for what car) are you using? Also, which halfshaft?</TD></TR></TABLE>
B16a motor in a civic 93 3dr... using Acura Integra Axels (ABS)
which halfshaft? I dunno... the one the b16a came with... my tranny has LSD if that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SicilianSpeed42 »</TD></TR><TR><TD CLASS="quote">i dont think the fluid would help unless you have none in there....also, the problem could be your wheel bearings</TD></TR></TABLE>
as in the hubs? in the Control Arm?
