b16 idle problem???? help!
Old Feb 15, 2006 | 04:24 AM
EGNA's Avatar
Default b16 idle problem???? help!
a couple weeks ago my distributor went out so i had to replace it and i went ahead and replaced the spark plug wires as well
after starting the engine it stayed reving a 3000rpm, i drove it around the block and after a few minutes of driving-warming up....it began to rev between 1000 and 3000rpm whenever i had it in neutral or pushed the clutch it, IACV? FIAC? what could be the problem? thanks
Old Feb 15, 2006 | 04:31 AM
THC07's Avatar
Default Re: b16 idle problem???? help! (EGNA)
you replaced the dizzy? you sure you got the timing right?
Old Feb 15, 2006 | 04:34 AM
EGNA's Avatar
Default Re: b16 idle problem???? help! (THC1107)
heh i didnt time it, thought that was the prob but i dont have a timing light, i was planning on usin my buddies after school today
unproper timing will cause it to idle at 3k though? looked at how to time and it did say something about reving at 3k
Old Feb 15, 2006 | 04:35 AM
EGNA's Avatar
is it bad to drive w/ bad timing for a day? cus i needed to drive my car to school because i have to work right after i get out
Old Feb 16, 2006 | 12:21 AM
blucivicSl
Guest
Posts: n/a
90% cance this will fix it:
https://honda-tech.com/zerothread?id=1003988
Old Feb 16, 2006 | 12:23 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: b16 idle problem???? help! (blucivicSl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGNA &raquo;</TD></TR><TR><TD CLASS="quote">is it bad to drive w/ bad timing for a day? cus i needed to drive my car to school because i have to work right after i get out</TD></TR></TABLE>
It could be bad. I wouldn't do it.
Old Feb 17, 2006 | 06:36 AM
EGNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blucivicSl &raquo;</TD></TR><TR><TD CLASS="quote">90% cance this will fix it:
https://honda-tech.com/zerothread?id=1003988</TD></TR></TABLE>
ya i fixed it a couple days ago, but there was a vacuum leak, one of the hoses in that thread was actually the one that was loose, heh thanks anyway!!
StevenGunn
Nov 21, 2010 03:23 PM
NoVALude
Nov 20, 2006 11:02 AM
bassysingh
Oct 17, 2005 10:02 AM
Blueallie
Dec 11, 2004 09:16 PM
REDBARON
Oct 4, 2001 07:40 PM
