surface of mild steele flanges after a while
Old Feb 15, 2006 | 12:54 AM
hondaapi's Avatar
Default surface of mild steele flanges after a while
I know that a lot of people/companies use mild steele for there head flanges in these days. But how look these flanges after a while of use in the cars?
I think that stainless will look much better.
What do you guys think are all the advantages of the mild steele? Or is it the lower price of the mild compared to stainless?
Thanks
Old Feb 15, 2006 | 05:12 AM
The sweed's Avatar
Default Re: surface of mild steele flanges after a while (hondaapi)
stainless expands too much and if you have bad luck can rip the threads out of your head..
Old Feb 15, 2006 | 07:04 AM
hondaapi's Avatar
Default Re: surface of mild steele flanges after a while (The sweed)
I ever thought the stainless flanges can shear the studs and this problem could be solved with making the holes in the flange big enough?
What do you think?
Old Feb 15, 2006 | 07:18 AM
fabnewb's Avatar
Moving in general. Welding it, expansion of all sorts. Then the warping that can happen. Making the holes bigger may work with expansion on the X axis. However when the flange warps and lifts from the head it will still rip off teh studs.
Old Feb 15, 2006 | 07:20 AM
Ekasey's Avatar
Default Re: surface of mild steele flanges after a while (fabnewb)
Why not just use a different stud? This is a rare occurence
Old Feb 15, 2006 | 07:28 AM
tony1's Avatar
Default Re: surface of mild steele flanges after a while (Ekasey)
I've heard about stud problems, but i've never seen it and don't really believe it to be much of a problem. My main complaint is that the stainless flange will warp ALOT more than a mild steel flange while welding.
Old Feb 15, 2006 | 07:35 AM
Ekasey's Avatar
Default Re: surface of mild steele flanges after a while (tony1)
True nothing a 20" Surface grinder can't fix tony i heard you could weld without using any heat? something about just looking at the material and it welds itself
Old Feb 16, 2006 | 12:38 AM
hondaapi's Avatar
The flanges of the first five or six manifolds that I´ve buildt have shrinked or warped. While checking this, I niticed that they all shrinked ond warped in the same way.
I calculated this into my "flange production". I placed all the holes in a little different location before cnc-ing.
So, after welding they are all into the right location.
92cxturbo
Welding / Fabrication
Apr 18, 2011 07:03 AM
Justin Olson
20
Jun 10, 2006 08:54 AM
hondaapi
11
Sep 6, 2005 01:00 PM
hondaapi
Sep 6, 2005 12:27 AM
