instaling Arp rod bolts with block in?
Going ls vtec,B18a, but i want to keep the botom end stock for now, the rebuild later. the only thing i want to do is replace the rod bolts with arp bolts. Can i do this with just droping the oil pan? or do i have to take the rods out? i was just thinking take out the old and change for the new. is this possible? THANKS
yah you would have a hell of a time trying to do it with the rods in the block.. you should also have the big-ends of the rods resized to ensure proper bearing crush.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch »</TD></TR><TR><TD CLASS="quote">yah you would have a hell of a time trying to do it with the rods in the block.. you should also have the big-ends of the rods resized to ensure proper bearing crush.</TD></TR></TABLE>
eeeexxxactly. Take em out
although it is a rod 'bolt', its pressed into the rod, and itll be hell trying to accurately replace them
blackcrx16
Nov 12, 2007 06:49 AM
