why would my low comp motor bogg out @ 4k (even when boosted)???
Old Feb 14, 2006 | 06:27 PM
hatchinprogress's Avatar
Default why would my low comp motor bogg out @ 4k (even when boosted)???
i just rebuilt my dohc zc with eagle rods, srp pistons, arp headbolts, delta cams(re-grinds) jg cam gears, new valves springs and retainers and brand new oem gaskets/seals......when i 1st drove it home (n/a) the car would bogg down when every i hit 4k rpm's, i didnt wanna go past 4k(once it bogged down) because it's a fresh re-build....someone told me it was because my compression was so low (and when i turbo'd the car (again) it well have the power back)
for the time being i threw my old t-25 back on, and it still bogg's at 4k, today i revved past 4k and it felt like a lil more power(till a coupler came off).........so why would my motor still feel that way with boost? oh and the only code im throwing is #10 i.a.t.
Old Feb 14, 2006 | 06:33 PM
Muckman's Avatar
Moderator in Chief
Default Re: why would my low comp motor bogg out @ 4k (even when boosted)??? (hatchinprogress)
how is it tuned?
Old Feb 14, 2006 | 06:38 PM
Default Re: why would my low comp motor bogg out @ 4k (Muckman)
right now i have a base map (i need to get it tuned) made by xenocron, the map was made for the same turbo set-up im running now(except now i have an intercooler) and a built motor, i never had the bogging issue when the motor was stock
Old Feb 14, 2006 | 07:31 PM
Default Re: why would my low comp motor bogg out @ 4k (hatchinprogress)
ttt
Old Feb 14, 2006 | 07:36 PM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">right now i have a base map (i need to get it tuned) made by xenocron</TD></TR></TABLE>
thats your answer right there
Old Feb 15, 2006 | 04:10 AM
Default Re: why would my low comp motor bogg out @ 4k (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">
thats your answer right there</TD></TR></TABLE> but i used the same base map before and the car never bogged....why would it start to bogg now?
Old Feb 15, 2006 | 08:15 AM
boosted94cx's Avatar
* B A N N E D *
is it like..hitting a revlimiter....or just bogging?
if it's a revlimiter liek bog then it's in limp mode
Old Feb 15, 2006 | 12:26 PM
Default Re: (s13-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s13-t &raquo;</TD></TR><TR><TD CLASS="quote">is it like..hitting a revlimiter....or just bogging?
if it's a revlimiter liek bog then it's in limp mode</TD></TR></TABLE>it's like bogging, and if it was in limp mode wouldnt my ecu throw a code??
Old Feb 15, 2006 | 12:32 PM
Si Shane's Avatar
Default Re: (hatchinprogress)
What is your base timing? What does a timing gun say?
Old Feb 15, 2006 | 12:42 PM
Default Re: (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">What is your base timing? What does a timing gun say?</TD></TR></TABLE>my base timing is 21* (it was the lowest i could get it, i even turbed the dizzy all the way back)
Old Feb 15, 2006 | 04:58 PM
ttt
Old Feb 15, 2006 | 06:18 PM
GS-R Civic's Avatar
you don't have to throw a code to be in limp mode, that had me scratching me head for 3 whole days!
Old Feb 16, 2006 | 03:07 AM
Default Re: (GS-R Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-R Civic &raquo;</TD></TR><TR><TD CLASS="quote">you don't have to throw a code to be in limp mode, that had me scratching me head for 3 whole days!</TD></TR></TABLE>oh i didnt know that.....how can i get the car out of limp mode?
Old Feb 16, 2006 | 04:07 AM
SilCiv2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">my base timing is 21* (it was the lowest i could get it, i even turbed the dizzy all the way back)</TD></TR></TABLE>
Well 21* sounds a little too high as for base timing. Not sure on what it is for a zc but if 21* is the wrong base then it is throwing EVERYTHING off in the HI/LO map. What you need to do is (ex: say ur base timing was 16*) highlight both the IGN maps in the editor and subtract 5* from the whole matrix of numbers. This will make the timing per load/rpm spark just where it is supposed to. Also check your mechanical timing to make sure everything is set right.
Old Feb 16, 2006 | 04:17 AM
CoreyR's Avatar
Default Re: (SilCiv2K)
check your cam timing.
Old Feb 16, 2006 | 06:14 AM
Importordomestic's Avatar
try and check you cam timing marks again. It sounds like your cam timing is off
Old Feb 16, 2006 | 06:18 AM
splitime's Avatar
Default Re: (Importordomestic)
I also think that if you can't get good timing on your dizzy... the cam timing is off. Double check your timing belt.
Also... low comp won't cause a bog... I'm at like 8.5-8.7:1 and no bogging... but thats also with more than just a basemap.
Old Feb 17, 2006 | 09:18 AM
Default Re: (splitime)
thanks guys
Davidls
May 8, 2010 04:13 PM
riceball777
May 2, 2006 02:36 PM
00 blk si
Feb 17, 2006 06:45 AM
hatchinprogress
14
Feb 3, 2006 08:07 AM
x00gsr
Apr 21, 2004 07:08 AM
