98 Prelude Random Misfire
Old Feb 14, 2006 | 05:54 PM
speed_king-'s Avatar
Default 98 Prelude Random Misfire
The flashing engine light came on today so I took it to my buddy's shop and had it scanned with random misfire codes. I replaced the ignition wires, plugs, rotor and cap with oem replacements but it turned back on after a couple miles. Any help???
Old Feb 14, 2006 | 08:20 PM
BB6racer's Avatar
my friends EGR ports caused his cylinder #1 to missfire. howmany miles do you have? have you ever had the EGR serviced? and what kind of gas do you use?
Old Feb 14, 2006 | 11:42 PM
y0whuddupb's Avatar
Default Re: (BB6racer)
had this similar problem not to long ago. my check light threw out a code 4 (crank angle sensor) which i just replaced the whole dizzy. fix the misfiring big time!
Old Feb 15, 2006 | 04:03 AM
bigj505's Avatar
Default Re: (yO_wHuDdUp_B)
man, i dont know what it is about preludes, but my lude likes to display the check engine light. ive gotten the misfire code and i just changed the plugs and wires and the car was happy for like 3 months. then the light came back on and it was the O2 sensor. replaced the sensor and the damn motor and the light comes back on 2 days later........................
Old Feb 15, 2006 | 11:53 AM
my car has about 95k miles on it. could it be carbon build up in the egr port? because i've never had the port checked out. i'm using premium gas (91-93).
Old Feb 15, 2006 | 12:41 PM
prelude1897's Avatar
Default Re: (speed_king-)
May need to do a valve adjustment. I had the same code awhile back, then I did a valve adjustment, and it went away
Old Feb 15, 2006 | 04:33 PM
Mik3's Avatar
Default Re: (prelude1897)
My bb6 also likes to flash the CEL randomly for a coulpe of days and it would be misfire on cylinder 2 and 3. Maybe i should go get a valve adjustment.
Old Feb 15, 2006 | 04:53 PM
Where could i go to get the valve timing checked for the cheapest?
pixshooter
Sep 16, 2009 11:48 AM
axshnjxsn
Nov 9, 2008 07:04 PM
teg01type-r
Jun 14, 2008 10:09 PM
98civic_ex
Sep 24, 2003 04:54 AM
vtecfiendsh
Feb 12, 2003 10:10 AM
