Motor Flush?
Old Mar 26, 2002 | 08:09 PM
98GeeYes-Are's Avatar
Default Motor Flush?
What are your thoughts on using it? I've heard that the detergents in it are too harsh for our motors, is this true?
Old Mar 26, 2002 | 08:27 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Motor Flush? (98GeeYes-Are)
An old mechanics trick is to run a quart of auto tranny fluid through the engine for a minute making sure not to rev the engine and keeping it at idle (or you'll damage the engine). Than drain it all out, maybe flush the engine with a quart of oil and then fill it back up.
Old Mar 27, 2002 | 10:30 AM
anybody else?
Old Mar 27, 2002 | 10:35 AM
JL 74's Avatar
25 Year Member
I don't see it in the owners manual nor in the service coupons (e.g. 30k, 60k, etc. service specials)
As long as you don't add Slick 50 or some other ****, and change the oil often and while the oil is hot, flushing is probably not needed.
Old Mar 28, 2002 | 06:13 AM
keys's Avatar
Default Re: Motor Flush? (jl74)
I heard some motor flushes might contain some detergents that are too strong and harsh for our seals. I actually did GaryLube's ATF trick and my seals are just fine. Which reminds me I need to do another motor flush
Old Mar 28, 2002 | 02:05 PM
g's integ's Avatar
Default Re: Motor Flush? (Gee3)
newbie question. How often do flush your motor?
Old Mar 28, 2002 | 03:35 PM
Default Re: Motor Flush? (g'sinteg)
every other time i do my oil change
Old Mar 28, 2002 | 03:59 PM
gsr stuie's Avatar
I use stp engine flush at least twice a year. Pour in current oil, then start the car and run it at 2000 rpm for 10- 20 mins then drain the oil and change filters and replace with new oil. Trust me does no harm and you will be surprised what comes out.
STU
fragmare
10
Sep 10, 2012 08:23 PM
EK-R Hatchman
30
Apr 27, 2006 03:49 AM
Calean007
Feb 22, 2005 08:12 PM
variablevalve
Oct 5, 2004 01:36 PM
self_made
Nov 27, 2002 07:26 PM
