How To do K20 into EG???
Old Feb 13, 2006 | 09:27 PM
BOOSTED92EG's Avatar
Default How To do K20 into EG???
Check it... i know that i have to get the motor mount kit to put the k20 into the EG... but do i also take the axels from the RSX and put it into the EG too??? and how to hook up the shift linkage i know its cable shifter... and as far as wiring and ecu im going to use AEM EMU and will the AEM work on it??? thanks yall
Old Feb 13, 2006 | 09:37 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
This is the only post you get from me, if you really want information, search for it.
Here: https://honda-tech.com/zerothread?id=1274311
Old Feb 13, 2006 | 10:50 PM
x_outlaw_x's Avatar
i think this is one of those situations where if you have to ask how to do it you arent qualified to do it
Old Feb 14, 2006 | 01:46 PM
rising_son97's Avatar
Default Re: How To do K20 into EG??? (BOOSTED92EG)
its not that hard man if you can do a b-series then a kseries swap should be easy for you, but you will need more parts of coarse.
heres what you need:
swap
k20a typer ecu or compatible one, a hondata k-pro is the best but you can get by with a stock ecu cause k-pros are like 900 bucks, or the AEM EMS will work.
mounts from hasport
pnp harness for wiring from hasport
axles from hasport (or you can use the types with modifications, search for that)
throttle cable
header from hasposrt or other after market company
exhaust/intake
rsx shifter cables and box
shifter box adapter for karcepts
new/custom radiator supports
and Fuel regulator, rail (aftermarket if you want), fuel lines and walbro pump
put 300 aside for misc. stuff like hoses temp sensor adaptor **** you know
if you put a k20a2 in from the rsx type-s you can get this all done for just under 7 g's excluding labor, but just tacle the job youself, youll learn alot and its not really that bad if you are somewhat compitant with tools
Old Feb 14, 2006 | 05:22 PM
cisurfer1's Avatar
lots of money and know how
Old Feb 15, 2006 | 03:59 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: (cisurfer1)
k20a.org
Old Feb 15, 2006 | 09:43 AM
ECKOTYPER's Avatar
Default Re: (k25a2kid)
takes alot of research, and its different for everyone depending on what they have to begine with... for me stock rsx axels will work because i have a JDM 5 lug with 36mm spline, im guessing u have 32mm spline, so no they wont work u will have to cusomt make urs, or buy a custom set... etc... hit up k20a.org best way to get the info u need!
Old Feb 21, 2006 | 02:56 AM
TrueZen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k25a2kid &raquo;</TD></TR><TR><TD CLASS="quote">k20a.org</TD></TR></TABLE>
x2
Old Feb 21, 2006 | 04:51 PM
crazy4hp's Avatar
http://www.k20a.org. you find it in there.
Old Feb 22, 2006 | 07:25 AM
A L I A S's Avatar
x3
damn, you see atleast 1 of these threads a day...and this is a tad bit more involved than a b series swap.
theres also a bunch of little **** you need like an integra throttle cable b series outer axles fpr..blah blah it goes on...
and please search...they even highlited it in bright red for you...
Old Feb 25, 2006 | 09:57 PM
hndarcrb18c1's Avatar
Default Re: (A L I A S)
Just pay me to do it.....
jcalderon
Jul 2, 2007 09:43 AM
SupraRXZ
Jun 3, 2007 11:46 AM
JDM_Frijoles
Feb 4, 2007 03:04 PM
adammilad
Oct 18, 2006 11:28 AM
bjfisher
16
Apr 14, 2006 07:33 AM
