CTR piston setup
Old Feb 13, 2006 | 08:00 PM
Master23's Avatar
Default CTR piston setup
Just got some new CTR pistons for my B16a. I've been doing research all day on honda-tech and i came to the conclusion that i would have to mill the b16a rods about 1mm for clearance. Does that sound right to you guys? Is there any other b-series rods i could use on a b16a with CTR piston with no clearance problem?
Old Feb 14, 2006 | 07:10 AM
JDMCivicEF9's Avatar
Default Re: CTR piston setup (Master23)
Yes you need to mill 1mm off each side of the B16 rods to get the CTR pistons to fit. I recommend getting them shotpeened also. Thats what I did.
Old Feb 14, 2006 | 10:03 AM
Master23's Avatar
Default Re: CTR piston setup (JDMCivicEF9)
I really don't want to mill off 1mm from the rods, could i use a LS or GSR rods? Well since you had it done already, hows the motor running?
Old Feb 14, 2006 | 06:57 PM
Master23's Avatar
anyone?
Old Feb 15, 2006 | 08:56 AM
Its running GREAT! No problems at all. Just make sure the machine shop you're getting it done is legit. A few of my friends did this also, no complaints from them.
HondaTrac
Jan 11, 2006 09:44 PM
hybridpatient95
Aug 6, 2005 04:25 PM
2 litre EG
Apr 16, 2002 10:53 AM
